Question about HP Compaq 610 T5870 156 WH248UTABA (WH248UTABA) PC Desktop
I have a problem with my notebook: HP compaq 610. When i try to turn it on without the charger (using the battery) the screen goes black after the PC loads the operating system. I can see the the des
In safe mode the notebook works perfectly even with battery. Windows 7 home premium is installed on the notebook. My previous operating system is Vista Home basic. The problem was realyzed in the Vista, so i tryed to reinstall the pc to a Windows 7 home premium but didn't help. Sometimes when i try to turn the notebook on without the charger it suddenly turns off.
  • HP Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets. some Motherboards Cmos batteries are soldered in.
Hope this helps.
Posted on Jan 09, 2013
Testimonial: "thanks"
  • 18 more comments
  • Ladislav Ondrejkovic
    Ladislav Ondrejkovic Jan 10, 2013
    Thanks for your ansver, i tryed it all but poorly it didn't help. I posted a video how the machine acts when turned on with and without charger. please watch it :). Also. it works with battery when turned on in safe mode.
    I tryed to start it without a charger, and sometimes while turning on, the pc force-shutdowns and gives out the same noise as when i push the shut down button for a long time to force shut down the pc. i feel hopeless
  • Brian Sullivan
    Brian Sullivan Jan 10, 2013
    Have you done a virus and malware scan ? if it works ok in safe mode something might be interferring possibly malware or a virus if you select safe mode with networking you can downloadhttp://corbitek-antimalware.soft32.com/free-download and run it if you dont have any malware protection
    soon i try it :) thanks. by the way, shouldn't the maleware be removed after the reinstall if there was one? i also erased the hdd. before installing the windows 7 operating system
    still worths a try :) thanks
  • Brian Sullivan
    yes after a reinstall all virus or malware will be wiped if it does not work you could try the system restore
    No spyware or virus found. scanned with the software you gave and with AVG 2012. I also measured the battery voltage. It's 11V. The battery works at 10.80 voltage. It's fine. I am totally hopeless. what now dude? :)
  • Brian Sullivan
    Identifying bad capacitorshttp://www.youtube.com/watch?v=ngA4k32jL... How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0ph... Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY... although if it works in safe mode check ram modules even remove clean gold or copper tabs with methylated spirits allow to dry then reseat have a look in the event viewer to see what errors or events might be occuring Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER and see what is occuring
    I checked the event viewer, and there were some errors. screenshot:http://img705.imageshack.us/img705/7922/...
  • Brian Sullivan
    Runtime Errors Some applications may be causing a conflict. Many times runtime errors are a result of incompatibility between two or more programs.Press the "Ctrl," "Alt" and "Delete" keys simultaneously to open Windows Task Manager. From the "Applications" tab, close each open application until the runtime error is resolved.Check for patches, bug fixes or upgrades by visiting the manufacturer's website.Search for your product and determine whether there are downloads to fix the problem your PC is experiencing. When none of the above fixes help, reinstall the troubling program. In severe cases, you may need to reinstall your operating system. Make sure that you back up the other programs and files you want to preserve, which may be erased during the re-installation.
    Ladislav Ondrejkovic Jan 12, 2013
    I just realyzed that this can not be software-related. When the pc is turning on, and didn't load the windows yet, randomly shuts down. The battery's voltage is normal, but there may be a problem in the battery. Poorly i don't know anyone who has the same battery type. The pc starts in safe mode, but the random shutdown remains. I am almost sure the battery is the problem. I sprayed the contacts of the battery and notebook with contact liquid, and cleaned the fan, but didn't help.
  • Brian Sullivan
    Brian Sullivan Jan 12, 2013
    have tried removing ram modules clean copper or gold tabs with alcohol Methylated Spirits allow to dry then reseat
    nope i didn't doing it soon
    did it. The problem still persists
    if we manage to fix it, i send you a medal :D
    The PC is cleaned of dust, contacts cleaned with contact liquid, battery voltage is okay, (10,8V is written, 11V is meansured).
  • Brian Sullivan
    Do you have any all in one tune up programs installed on your computer ? your computer might need a good tune up and install some important updates your registry might need a good clean up you can obtain freeware programs from the internethttp://support.microsoft.com/kb/982670 updates for net framework . Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-1... JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. something has become unstable could be loose connection bad or faulty driver. http://download.cnet.com/slimdrivers-fre... Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
    Ladislav Ondrejkovic Jan 13, 2013
    Upgraded .net framework, cleaned the registry, i have the latest drivers, and cleaned the pc, but there was not much to clean since it formated a day ago. The problem still persists.
    I could manage to try the notebook with a new battery. The battery was the problem. Something is wrong inside the battery. Thanks for your support. If i want it to work with a battery i will have to buy a new one.
  • Brian Sullivan
    Brian Sullivan Jan 13, 2013
    well done hope it goes well now
    Scholar:
    New Friend:
  • 58 Answers
Computer black screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive , It also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer black screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can be used to burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are few free software for you to use, so if you want to take this solution money is indispensable. Windows Boot Genius owns a better cost/performance among such kinds of software I've used. It may be a good choice for you if you have money to pay.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
source:http://www.reset-password.net/black-screen-of-death-and-blue-screen-of-death.html
Posted on Jan 18, 2013
3 Suggested Answers
SOURCE: HP Pavilion Elite m9517c Desktop PC stuck on welcome screen
hi
there is problem with windows OS
u have to reinstall wondows befor you go for reinstall just tak backup from you C drive
Posted on May 21, 2010
bbl242003
  • 1637 Answers
SOURCE: Received 512 - chassis fan error on HP Compaq
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Posted on Jan 12, 2011
Hello, I've had my HP Compaq 610 T5870 156 WH248UTABA for some time now, and the screen has suddenly gone white. I can still hear music from the computer and the windows 7 desktop still operates. I...
Restart the notebook and check. If the issue still persist, disconnect the power cord, take out the battery, press the power button for 30 seconds to drain out static electricity.
Connect the battery back and turn the notebook on and check, if the issue is still there your notebook needs a repair. The screen has gone bad, the graphics chipset is good as you are getting a display on your TV.
Regards,
Shrey
Jun 08, 2011 | HP Compaq 610 T5870 156 WH248UTABA...
I have a compaq nx 8220 from 2006 everything seems to be perfect till last week. 1.when i press the start button to open the display goes black and nothing is happening. 2.if i manage to start it ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx8220 Notebook
Blue screen of death, over heat
Aug 28, 2010 | HP Compaq Presario C769US Notebook
Compact nx 9110 screen does not light up can only see slightly
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 10, 2010 | HP Compaq nx9110 Notebook
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hp tx 1000 black screen please hel
Nov 28, 2009 | HP Pavilion Tablet Notebook
I turn my laptop on and its black
Nov 19, 2009 | HP Compaq nc6120 Notebook
My compaq r4000 is powring on but nothing is coming up on the screen
Oct 29, 2009 | HP Compaq Presario R4000 Notebook
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
HP Compaq 610 T5870 156  WH248UTABA (WH248UTABA) PC Desktop Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
