Question about Sony Handycam DCR-DVD308 DVD Camcorder
Sony dcr-dvd308 movie recording disabled error
SOURCE: Movie Recording Disabled
guys hope you all found the solution like me who had same issue. if you noticed, it says about the aspect ratio and that means the formated disc aspect ratio is not compatible with the aspect ratio your camera need. so re-formating the dvd with right aspect ratio solved the problem quickly and we have peace.
bayaraa
Posted on Jul 05, 2008
robmcd27
  • 423 Answers
SOURCE: How can i fix the "movie Recording Disabled" on sony DCR-DVD108?
Hi there. I undertand how upset you must be. I would be if it happened to me. Did you check the manual for this error code?
If you didn't, I'll tell you what it means. It means one of 2 things: 1) you have a bad disk or:
2) you are trying to use a disk that has been finalized. Once a disk has been finalized, it cannot be recorded on.
I'm sorry, I know it's a bummer, and it's not what you wanted to hear, but it happens occasionally. There is no fix for it. You just have to get a new disk and record it again.
Thanks for using FixYa, and if you have any further questions, just comment back. If you don't mind, please rate my solution a fixya.
Rob
Posted on Feb 25, 2009
  • 80 Answers
SOURCE: Sony Handycam says movie recording disabled. How
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
Posted on Aug 11, 2009
  • 85 Answers
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Posted on Mar 20, 2010
shajanrs
  • 890 Answers
SOURCE: My sony handycam carl zeiss
Most probably it is an issue with the disc. If the disc is corrupted, it will display the error message to prevent spoiling the lens of the Camcorder. Please use a different disc and it should resolve the issue. If the issue persists with different discs, it may require service..
However, I suggest that you reset the Camcorder by pressing the Reset button behind the LCD panel (Near to the USB port) on the Camcorder) Please make sure that you have turned ON the Camcorder while pressing the reset button.
Posted on Jan 18, 2011
How can i fix the movie recording disables error on dcr-dvd610
How can I fix the movie recording disabled on Sony Handycam 40x???
Sep 09, 2012 | Sony Handycam DCR-DVD108 DVD Camcorder
Cannot locate manual. When I turn on the camcorder to try and record, I get an error message that says, 'Movie recording disabled'. How can I correct this?
You can download the manual (and more) from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD610
May 16, 2011 | Sony DCR-DVD610 DVD Camcorder
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
"movie recording disabled". How do I enable it?
If you are using DVD-RW, format it because it got some error in data writing.
and if its DVD-R, use another disc and try to finalize existing DVD-R / DVD-RW to get data.
Thanks.
Sep 13, 2009 | Sony DCR-DVD610 DVD Camcorder
that message must be a R/w controller Feedback.
This post might help u
http://www.avforums.com/forums/camcorders-video-editing/370724-problem-sony-dcr-dvd305-recording-disc-disabled.html
Sep 09, 2009 | Sony Handycam CCD-TRV37 Camcorder
   Just delete unuseful data from drive or connect the camrea to your pc cut the required movie and paste it on your pc drive then it will work.
Thanks for using fixya.
Feb 15, 2009 | Sony DCR-DVD608E DVD Camcorder
DCR-DVD308 Camcorder problem
There sas a tiny screw probably from the manufacturers that was sitting on the DVD mechanism witch prevented the DVD to sit properly. So I removed the loose screw. Now works wonderfully.
I checked everything on the camera and doesn't have any screws missing. Thanks. Grace
Feb 06, 2009 | Sony Handycam DCR-DVD308 DVD Camcorder
Sony dcr-sr40 reporting movie recording disabled
Please remove my question, I didn't realize this was a premium site and not just good people helping with something they've learned.
Jun 28, 2008 | Sony Handycam DCR-SR40 Camcorder
Does it give any error message on display LCD?
May 30, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam  DCR-DVD308 DVD Camcorder Logo
369 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
