Question about Acer Aspire M1641-U1521A PC Desktop
I rebooted my acer aspire m1641-U1521A and now all I get is bootmgr in upper left corner. Will not do anything else
  • Acer Master
  • 27,725 Answers
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order Hope this helps. BOOTMGR Is Compressed b> The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
Posted on Jan 09, 2013
  • Acer Master
  • 2,878 Answers
Boot with a Windows 7 installation disc and choose repair. There is a boot manager repair.
xclancy
  • 82 Answers
SOURCE: does acer aspire m1641 have blue tooth
No. I don't think Acer Aspire M 1641 comes with Blue tooth
Check the Specification for Acer Aspire M 1641
If this is the Desktop you are talking about, then It is not bundled with Blue tooth
i hope this might resolves your query
Posted on Jan 05, 2009
billspeer
  • 180 Answers
SOURCE: We just need a manual for our m1641 aspire by acer
http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/45e5dbfae8f0aab4482573620035095b?OpenDocument
This was the closest I could find for you. I didn't actually see your exact model. If this doesn't do you any good, the only other bet would be going directly to acer through their tech support or email to have them send one. Most likely it will be an email with the document attached.
Posted on Jan 08, 2009
  • 50 Answers
SOURCE: can i have some links to download manual for aspire m1641,, tnx
Hi! Try downloading it for free from www.retrevo.com Just select your model number, enter the code, then download. You have to have Acrobat Reader installed on your computer to open the .pdf files. It also can be downloaded free at www.acrobat.com If this helps you, please rate this answer. Thanks! Hal
Posted on Jun 14, 2009
SOURCE: Windows Xp Sp3 installtion problem with Acer Aspire M1641 Desktop
Actually WinXP SP3 should help your problem but if that don´t work than maybe you can try to install XPSP3 in another computer and try to install into your Acer Aspire*
Posted on Jul 07, 2009
wayneard
  • 1901 Answers
SOURCE: how can i connect to internet in my acer aspire
Yes, you will need to reinstall the drivers for individual hardware.
Go to http://gd.panam.acer.com/home/
Click on Desktop>Aspire>M1641 and the available downloads will be listed.
These drivers wil be downloaded in .zip format. They will have to be extracted to their full size after downloading. If you are not familiar with doing so, just Comment back and we will try to guide you.
Thanks for using Fixya.
Posted on Nov 10, 2009
Testimonial: "THANK YO VERY NICE HELPFUL"
Acer Aspire M1641
have you installed any new hardware.? done any change in BIOS ? for the the freezes you proberly.got to little RAM.you can't have enough RAM.try install moore RAM. try that first.if still blue screens you have to be a detectiv.
Apr 05, 2013 | Acer Aspire M1641-U1521A PC Desktop
My acer aspire m1641 lost operation system,
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 24, 2012 | Acer Aspire M1641-U1521A PC Desktop
I need drivers cd for m1641
http://us.acer.com/ac/en/US/content/drivers
To access your drivers select
Desktop
Aspire
Aspire M1640
All content drivers are listed for download, if you cannot access the internet on this PC, I recommend getting on another PC with internet access. Download the drivers and burn them to a CD or flash drive, then transfer and install on the Acer Aspire M1641-U1521A.
Good Luck,
Rodrick
Apr 23, 2011 | Acer Aspire M1641-U1521A PC Desktop
Does the acer m1641 have bult in sound
Yes this computer has a built in audio/sound card , here is the complete details about this unit.
http://reviews.cnet.com/desktops/acer-aspire-m1641-u1521a/1707-3118_7-33234219.html
Aug 21, 2010 | Acer Aspire M1641-U1521A PC Desktop
Anyone got a recovery disc for acer m1641?
http://rapid.tvphp.net/?q=acer+aspire+m1641+recovery
Should work
Nov 26, 2009 | Acer Aspire M1641-U1521A PC Desktop
Hello, I am hamid, I need driver audio acer aspire m1641 for os xp sp2
you can download it from http://komku.blogspot.com/2009/01/aspire-m1641-m3641-m5641-windows-xp-and.html.
May 19, 2009 | Acer Aspire M1641-U1521A PC Desktop
Does acer aspire m1641 have blue tooth
Jan 05, 2009 | Acer Aspire M1641-U1521A PC Desktop
Acer Aspire M1641-U1521A  PC Desktop Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
