Question about Olympus ? Stylus 500 Digital Camera
Set the timer
I have stylus 500, 2.5 digi cam,,, i want to set timer in it,,,, indeed it has button but when i press this it suggest ' OFF',,, how to put it 'ON' and set timer
    Novelist:
  • 150 Answers
  1. Place your camera on a tripod and prepare your scene.
  2. While in a shooting mode, press the timer button (the bottom button in the circle set on of the back of the camera). Press it repeatedly. It will cycle through self-timer and remote-control. On the screen, a Timer will appear for the self-timer and a little Remote with a lightning bolt will appear for the remote-control. Stop pressing the button when the timer appears, pause for 3 seconds to allow the camera to confirm the setting the icon will disappear.
  3. These instructions are described on Pg 55 of the manual, but I will repeat them in simplified form in case you don't have the manual.
  4. Once the timer setting is set, press the shutter-release button fully. If you press it half-way it will focus and lock the exposure, then press it fully.
  5. The self timer/remote control lamp will light for 10 seconds. Get in position in the scene, after the 10 seconds the light will begin blinking. After 2 more seconds, the picture is taken.
  6. To cancel the timer mode, press the Timer button again; however the timer mode is automatically canceled after one shot.
It is important in all timer scene shots with cameras, don't stand directly in front of the camera because this will then focus on you instead of the scene.
Posted on Jan 21, 2009
Where is the on switch, for constant hot water located?
Question posted under Taco digi timer control
http://waterheatertimer.org/images/Digi-dial-image.jpg
http://waterheatertimer.org/images/Taco-265-3-timer-600.jpg
Taco must have stock of old digi timers because that timer is discontinued.
It's a good timer. It's just been replaced by less attractive, more complicated digital timer with fewer buttons.
The manual switch for this timer is located at top and is denoted by 'hand' symbol.
Press left side for ON and right side for OFF.
Aug 23, 2011 | Taco 265-3 Digital 7 Day Programmable...
How do i set the timer on my olympus 500 digital camera
Press down on the cursor pad (marked with a one-handed clock) to cycle through the self-timer modes. Start the self-timer by pressing the shutter release button.
Jun 24, 2011 | Olympus ? Stylus 500 Digital Camera
My Grasslin Digi 20E-120 timer will not set time or timer. The 1-7 numbers blink. What does this mean?
Digi 20E-120 is 16Amp 120Volt flush mount digital timer with 20 or 140 programs per week.
Grasslin Digi (digi tal/ digital) can be reset using reset button.
Reset might restore functionality, but will delete all programming.
Check that circuit is delivering 120Volt and that circuit is clean without interference.
Also check electrical terminals fit tight on the timer.
Use needle nose pliers and pull terminals off and then push back.
The digi series has 5-day program back-up capacitor so programs should remain, but capacitors go bad.
Power surge can blow out timers. Use surge protection on all circuits.
There are a many Digi timers from years of manufacture by GE and now Intermatic, since Intermatic bought Grasslin from GE.
The digi can be replaced with simple-to--program FM1D digital timer.
Replacement crossover is FM1D20E-120
Open following link for FM1D manual and Digi manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 18, 2011 | Water Heaters
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Format Stylus 500
    Press >menu< button, select >mode< select >card< select >format< select >yes< press >ok< (menu button)
    During formatting DO NOT open battery cover, card cover, or plug in AC adapter.
    Make sure you have all your files saved on your computer or elsewhere before formatting your card, since all images will be deleted.#
    Hope that helps
    Jul 27, 2010 | Olympus ? Stylus 500 Digital Camera
    How to set the self timer of the canon powershot s45 digi camera?
    Press the +-/WB/FUNC button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select two-second or ten-second delay. Start the self-timer by pressing the shutter release button as normal.
    May 26, 2010 | Canon PowerShot S45 Digital Camera
    How do I set the timer?
    Press the self-timer button. It's the bottom part of the cross-shaped button on the back, marked with a clock icon. Each press of the button cycles between ON and OFF.
    After pressing the shutter release button completely, the self-timer lamp lights for approximately ten seconds, blinks for approximately two seconds, then the picture is taken.
    To cancel the self-timer, press the button again.
    The self-timer is automatically canceled after one shot.
    Mar 29, 2010 | Olympus Stylus 850SW Digital Camera
    Olympus stylus 710
    I have aproblem with my stylus 710 digi cam an error saying that 5fo8 on screen pls, help me to solve my problem.ty
    May 15, 2008 | Olympus Stylus 710 Digital Camera
    Epson rx 500 "service required"
    I put the error message into Google and was directed to a site whihc suggested a sequence of button presses that re-set the printer. Sorry I stupidly did not keep the site or details - it involved pressing about 5 buttons at the same time and worked a treat.
    Apr 24, 2008 | Epson Stylus RX500 All-In-One InkJet...
    Date and time
    With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select ‘time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
    Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
    Olympus ? Stylus 500 Digital Camera Logo
    146 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
