Question about Whirlpool GEW9250 Electric Dryer
Dryer wont turn on
Control works, when you hit start the light moves to sensing but the motor doesn't start
    Problem Solver:
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Posted on Jan 22, 2009
1995 Ford Explorer 4 wheel drive trouble, front wheel drive doesn't work
Something you can do is to tap the 4/4 motor under drivers side on the back of transfer case with key on engine off. Have someone work the buttons as you gently tap the motor. Don't hit so hard as to dent it. Usually works.
Feb 22, 2013 | 1995 Ford Explorer 4.0
I have a fisher and pykel top loader model GW611, when starting on any cycle, on filling the maching the water will pause every so often and may not fill. when it decides to, it starts beeping and shows...
Your fault code is 112
Info for your fault code.
112. (01110000) Motor Current Sense Too High
This fault occurs if the Motor Control Module detects that the motor current has reached an
unrealistically high level for greater than 2 seconds. This suggests that the motor current
sense circuit is faulty.
Primary source: Motor Control Module.
Action: Replace Motor Control Module.
Oct 25, 2012 | Fisher and Paykel Washing Machines
Will only work with light amount of clothes in dryer, if medium amount just hums and will not start
With the door open hold in the door switch in and turn the drum while someone hits the start switch, if the dryer starts when you do this you may have a bad motor, what this is doing is "jump starting" your motor winding's. If it doesn't start by doing that then you may have a problem in your belt/idler pulley system.
Apr 21, 2012 | Dryers
My dryer will turn on, when I push the start button the sensing indicator lights up, but the drum doesn't turn and no air flows. I had a tech come out and tell me it was the main control board. We...
Most dryers have a belt that goes around the drum attached to a spring pulley and the motor pulley, if the belt breaks. the drum will not spin. and most dryers also have a safety switch in between the door and the dryer, if this switch is bad,will not let the drum turn. most dryers have a vented slot in the rear of the machine at the bottom, if you remove this vent you should be able to see how the motor moves the drum. good luck!
Aug 19, 2011 | Whirlpool Dryers
I have a 07 ninja 650r and it will not start. I have ensured that the bike is in neutral and the kill switch is where its suspose to be but no joy. I turn the key its lights up the oil and neutral lights...
Even though the transmission is in neutral...is the neutral light workimg?
To satisfy the interlocks, even if the light works.....try starting with sidestand up, and the clutch pulled in.
If it now starts...the interlock ciccuit is not sensing the bike is in neutral. If the light doesn;t work....inspect the wiring for your neutral switch ....usually the circuit grounds through the switch to the crankcase so any wiring break will prevent it from working.
Mar 13, 2011 | kawasaki Ninja 250R Motorcycles
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
I start work in a plastics factory as an electrician. I need to know the type of work I might expect to have to do. Maybe some diagrams of motors and generators may help.
You can start here with this video, what is a PLC. To get a better sense of What is a PLC, see http://plc-training.org To get a better sense of what all is involved on the industrial electrical side, see http://bin95.com/Industrial-Training-Videos/industrial_electrical_training.htm
Oct 17, 2009 | Electrical Supplies
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
92 deville with no brake lights or cruise control
the car works great? you have almost ten questions on here about this car. One you said the motor wont start. anouther you said the car runs but then stalls when you stop or turn. so why dont you post what is actually wrong with it so it can get fixed?
Nov 08, 2008 | 1992 Cadillac DeVille
Control panel inactive
See if you accidentally unpluged or damaged any wires under the refer during the move. There are connectors that can sometimes easily pull apart if a dolly hits them.
Dec 17, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Whirlpool GEW9250 Electric Dryer Logo
454 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
