Replace battery in Cabela's DT300 reel
How / where do you replace the battery in the DT300 reel? I tried prying twistin ect, thanks ..Mike
  • Audio Player... Master
  • 1,258 Answers
Just call Cabelas Customer service people. I think they have a big place in Hoffman Estates IL.
Posted on Jan 27, 2013
Where can I get Ryobi fishing reel schematics and replacement parts for a Ryobi AX123 spinning reel?
Contact The Reel People at this link I've provided. Home
Mike Willey shouled be able to help you out.
Oct 21, 2014 | Fishing
How do i replace bail spring on pfluger 7430 fishing reel ?
Reel Schematics
This is a link to the Pflueger page where you can download a schematic of your reel so you can see how to replace your bail spring. If you require further assistance contact Mike Willey at the following link. Home
Sep 26, 2014 | Fishing
Where can I purchase the battery required to operate the Wildgame YN1 wireless access point?
You can purchase the battery for your unit at pretty much any major sports outfitters stores.
Cabela's and Bass Pro Shops will most certainly have what you are looking for.
Oct 17, 2011 | Wildgame Innovations yN1 Fieldnet WiFi...
Miele silver moon s558 powers up sometimes not others, very light use, all filters clean, will not power up with power head attched or not. Is there a fuse to change? Is there anything a home owner novice...
That's remarkably good news. You can almost certainly fix it for about twenty cents in about twenty minutes. First, open the main bag chamber, and remove the upper bag chamber lid. This can be achieved by gently prying back the tabs back by the hinges, and then sliding the whole thing upward. Next, you'll want to remove the exhaust filter and the two screws holding the control unit to the back of the vacuum. (The black part.) Lift up at the front of the control unit and it should lift away. This may make a terrifying snapping noise, don't worry about it. You didn't break it! Next you'll need to remove the screws that hold the main chassis onto the base. I believe there are roughly seven, in a perimeter around the chassis, if memory serves. Note that there are a couple up by the handle part. Once they're all removed, the whole thing should lift right off. Now, here's the actual cause of your problem. Over time, the cord reels in these guys start to wear out a little bit, and what happens is that the electrical contacts that keep power flowing through your reel start to move apart from each other. Locate the cord reel, which should be hanging out in the base area. Grab the white reel itself and wiggle it left and right. See all that play? So here's the fix: get a ziptie from an auto parts store or any place like that. Remove the screw holding the cord reel assembly into the machine and lift out the cord reel. When looking at the reel, you should be able to see the electrical leads that come out of the center of the wheel: one black, one white. On the OPPOSITE side of the reel from those wires, you're going to want to put the ziptie around that central axle. This will then take out all that slack you were feeling. Make sure you clip the end of the ziptie before you re-install your reel. Place the cord reel back in the body and then make sure you re-thread the cord through the hole in the back of the chassis. Place the chassis back on, replace the screws. Place the control unit back on, and replace the screws, snap the chassis lid back in, replace your bag and filter, and you should be in business. Please note that this works 99% of the time, but occasionally a reel will wear out to the point where this fix won't work. If it does, you do now know how to install it, so you shouldn't have to pay anyone else to do it for you. A new reel costs about $120, which is why I ALWAYS tried this fix first. Also of note: I wrote these instructions from memory, so if you're trucking along and you find that I've missed something somewhere, post another clarification request and I'll walk you through it. Good luck! -R
Sep 23, 2011 | Miele s558 Silver Moon Vacuum
Need instruction manual for outlet timer#59732 Model#DT300 125v/60Hz 8.3amp/1000watt resistive. Only other #s isee 227259
Open following links for possible DT300 manual:
I don't see load rating in manual, but 1000Watt would be typical for timer with 2-prong outlet.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
If manual is not correct:
Other folks have asked for DT300 manual, but didn't like provided manual.
Timers can have many different numbers, and different timers can go by same number:
1) Add a comment with link to in-focus photo of timer posted on Flickr, for possible identification.
2) Open following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Aug 07, 2011 | Woods 17321 Outdoor Power Strip Timer with...
DT300, I charged the battery, can set the program, but not the clock.
DT300 shows re-chargeable battery, I didn't know there was a replaceable battery.
Add a comment with photo of your timer and battery to exactly identify product
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Try resetting timer.
Other Intermatic timers with battery have to be reset after battery change if timer does not function, but all these timers come with industry standard 1 year limited warranty and most go bad within a few years, although some last several years.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 03, 2011 | Intermatic Hardware & Accessories
I lost the instructions to program my intermatic digital lamp timer, model:DT300 Can you help me?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
The DT300 is not available from Intermatic
I guess they discontinued the timer
If internal battery will not charged, then the timer is no longer good
Oct 24, 2010 | Intermatic Hardware & Accessories
182 people viewed this question
 Grubhead
Grubhead
