Question about Refrigerators
Teka fridge ts-136.3 relay switch
I need a compressor relay switch for a teka fridge ts-136.3
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: my westinghouse virtuose fridge/freezer switches
I think what you are saying is that it "short cycles". Try the relay first.
Posted on Apr 27, 2009
  • 5370 Answers
SOURCE: Hi. We moved to a house with an integrated Teka A-FC1359 Fridge/Freezer. It was working fine. We switched it off 3 months ago. Now we've swithched it back on but it's not working.
It can be issue with faulty compressor capacitor.From main power outlet the power goes to capacitor beside compressor and from there power goes to compressor motor,then after that all unit works.May be that capacitor got shorted or loose from its actual connection.Or other possibility is faulty power wire of refrigerator.Get the wire checked with continuity tester to confirm its not broken in between.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Posted on Dec 23, 2012
Teka fridge freezer lightcome on but not working
2 common issue's
1. check power going to compressor (rear).
if there is power, you have no gas or faulty compressor.
If NO power to compressor, check
2. temp stat, (it's just a switch, controlled by heat/cool) turn off power and link the two wire's together.
turn on power and listen if it has started to run.
If Yes, DO NOT RUN. put back to they way it was and replace with new stat.
If No. call an engineer, WARNING a new fridge freeze might be cheaper.
Nov 24, 2014 | Refrigerators
Teka fc1350
Need to know the model number to see if the unit has a
circuit board thermostat or a mechanical thermostat.
If it's mechanical then the thermostat is bad and needs to
be replaced.
If it's electronic then either a relay on the board needs replaced
or the entire board. Which isn't cheap.
Oct 17, 2013 | Washing Machines
Teka freezer
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other.
if you provide your model number then it might be a special case. here is user information on one model Teka.
http://www.fridge-manual.com/teka/teka-tki2-325.html
Oct 02, 2013 | Jenn-Air Refrigerators
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
REFRIGERATOR NOT GETTING COLD
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. If the relay is ok there is a compressor problem or low freon it it don't start
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
May 30, 2010 | Refrigerators
Both freezer and fridge stopped workin. only the
make sure the overload relay and start ptc are properly connected to the compressor.also check the wiring. if the wiring is good either compressor is no good or you need to replace the over load relay and ptc switch.rare occasions the thermastat switch needs to be replaced.i hope this helps your problem.good luck i would like to here how things went for you
Jan 21, 2010 | Frigidaire Refrigerators
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
Kenmore side by side #50562991
The black pod is the compressor and the switch on the side is the compressor start relay. You either have a failed relay or a locked up compressor.
Most likely it is a burned out relay.
Unplug the fridge and remove the relay from the compressor.
Shake it. If it sounds like a lot of loose pieces are rattling around in it, it is burned out.
Be sure you replace it with the correct replacement part. A "fit-all" relay may work for a while then cause the compressor to fail.
Your model number has 106 in front of it. You will need to know that when looking up or ordering parts.
Post back if you have any questions.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
