Question about Yamaha RX-V557 Receiver
RX-V557 powerin on - Yamaha RX-V557 Receiver
Where does subwoffer plug in a in a yammaha rx-v557
A self-powered subwoofer would attach via a single RCA cable to the Subwoofer Output jack.
May 16, 2010 | RCA SP2660 System
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
Can"t hear on phone v557.
may be the speaker is not at the best or it is damaged due to which it's not giving an output to u
Jul 25, 2009 | Motorola Mobility V557 Cellular Phone
Possible burnt out power supply on Yamaha RX-V557
Can you check the power transformer, voltage & resistance.
You may have to unsolder some components to test them...such as the rectifying diodes and the transformer.  I believe that the outputs from the power supply board are all DC voltages.  Is there all so a IC chip on the power supply board?  Does your insurance cover lightening damage?
Mar 25, 2009 | Yamaha RX-V557 Receiver
Speaker protection fault on rx-v557
Hello, you must first tested with a voltmeter in DC entrance if you have a DC voltage on all the terminal outlet speaker, normally you must obtain 0Vdc+/-50mV on each out speaker with control volume to minimum, you can stay or remove the speakers during this test.
BY
Sep 04, 2008 | Yamaha RX-V557 Receiver
Yamaha RX-V557 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
