Question about Pyle Digital AM/FM/USB Receiver - PT590AU
Want to put my pyle pt590au on my universal remote
Need user manual for Pyle model# prjand615 projector
Your best bet is to get it from Pyle directly. Here is s=a link to their contact page-
Pyle
Feb 26, 2015 | Universal HD Android 4.0 Multimedia Player...
I need redi-remote for a Pyle ptc40lc TV. How can I get one ? I have looked everywhere I can think of for days.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 30, 2015 | Pyle (PTC40LC) 40 in. LCD TV
Why won't my pt590au work?
Could be a system setting where HDMI inputs are not selected. Check the manual.
Aug 16, 2014 | Pyle PT590AU Amplifier
Could someone please help me with the 3-digit remote control code for my Pyle Pro P1001AT amplifier?
Since the code is generated by the REMOTE, it would help to know the BRAND of remote you plan to use. The code is not generated by your pyle amp
Mar 11, 2013 | PYLE Audio PYLE P1001AT 4-Channel 1000...
Ipod tower brookstone problem
The problem is with the speaker connector to your ipod. I have the same unit. Got to ebay and buy Pyle Home PIDOCK1 or similar docking station. This will solve your problem. You can plug this in and have full functionality back of your speaker. Don't bother trying to fix it these have a real problem with the connector and board buy yourself a docking station with remote for about $15 on ebay and it will fix you up. Plug into the input Jack and you are back in business. You can buy a Pyle Home PIDOCK1 Universal iPod/iPhone Docking Station cheap on ebay and it has a remote. It will fit nicely on your speaker and do everything you need it to do.
Jun 12, 2012 | Audio Players & Recorders
Pyle PLTAB8 Car Component System, Lights will not turn off. Help
Sounds like he did not wire a remote line from your radio to the amplifier, if he put a 12v from the battery to the amp and the remote spot on the amp then it will not turn off, you will need to either wore a toggle switch to the remote so you can turn it off manually or check the back of your radio for a remote line or splice a remote line from the accessory power supply on your radio so the amp will turn on when the radio is on
Feb 06, 2012 | Pyle PLTAB8 Car Component System
I need a code for a pyle tv
The best I can find for the Pyle TV is 0910. Not exactly a common model to track down.
Jan 24, 2010 | General Electric Universal Remote Control
How to change equalizer without remote?..Where to buy inexpensive replacement remote?
Original $40.00 here.
http://www.remotes.com/store/pyle/plts75.html
Can't even find it at Pyle. You might try eBay who knows someone might have had one stolen and still has a remote...The above link is the only place I found one.. Good luck!
May 10, 2009 | Pyle PLTS75 Car DVD Player
Pyle Digital AM/FM/USB Receiver - PT590AU Logo
106 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
