Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a craftsman diehard garage door opener. It has a sensor that the dog knocked offline. I have placed it back and get a green light meaning the beams line up, but you still have to hold the close button down until it is closed. Is there a reset button or something.
    Champion:
  • 244 Answers
No reset. green light is one one eye. what about the other. both must be on. did you activate lock on wall console.
Posted on Jan 22, 2009
My garage door opener is a 3/4 craftsman and one light is yellow and the other is green. I put my hand in front of the green light and the green light went off. the other side is a yellow light and it
Hi Vickie,
The safety beam portion of the garage door opener is set up to stop the door from closing if something (car, person, etc,.) is in the doorway.
When the door is open - if you press the hard wired push button (not the wireless remote) the door will either close until shut completely, or begin to close and reverse direction as soon as you let go of the button. When this happens, it *usually* means that a sensor is blocked - and reversing the door motor. If you try yhtis with the remote the door may not move at all or just bump down and stop.
You should re-align the sensors as described in the link below. Good luck!
How to Replace the Safety Sensor for Garage Door Opener Repair Guide Help...
How to Adjust Photo Eye on Garage Door
Nov 03, 2014 | Craftsman Professional 3/4 hp Hydro-Glass...
Red service light is on the diehard battery backup of my craftsman garage door opener.
time to change the batterys- they cost $90. and owner can install or a gdo repairer can, but consumer should, its harder to make coffee then replace these batterys.....
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of my garage door sensors is yellow while the other is green.
It means your sensors are properly aligned. Are you having a problem?
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do we reset our Craftsman 1/2 HP Part# 41A4315 - 7A garage door opener? When you press the button is goes down a little ways and then back up. The little green sensor lights will not come on either,...
If the lights in the door sensors do not light you have either a bad logic board or bad wiring to the sensors. Replacing the logic board is usually the cure.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
May 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Sears Liftmaster will not close
YOU PROBABLY HAVE A BROKEN WIRE ON THE SENDING EYE. THIS WOULD CAUSE IT NOT TO LIGHT AND THE RECIEVER NOT TO GET A SIGNAL MAKING IT NOT LIGHT.
YOUR DOG IS PROBABLY THE CULPRIT AGAIN . THEY TEND TO SNIFF AROUND OR JUST GENERALLY BUMP INTO THE WIRES (SOMETIMES THEY CHEW THEM).
IF NO OBVIOUS BROKEN WIRES OR LOOSE CONNECTIONS CAN BE FOUND. YOU CAN TEST THE WIRING BY USING DOOR BELL WIRE TO TEMPORARILY REPLACE IT - THE FAULT COULD BE INSIDE THE WALL OR UNDER A STAPLE WHERE THE WIRES GET SMASHED (THIS ONE WE CAN'T BLAME ON THE DOG) :)
IF YOU REWIRE COMPLETELY (PAY ATTENTION TO THE POLARITY OR THE TEST WILL NOT BE VALID) AND THE LEDS STILL ARE NOT ON YOU COULD HAVE A DEFECTIVE EYE
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
One green and one yellow light
jasonbonefa remove the cover and check the drive gear. It is most likely stripped.
If the sensor lights are on it means they are working.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster door opener and one of the saftey sensors always has a yellow light instead of green.
That is correct and not a problem.  One light should be yellow which means power and one light should be green which means the lights are lined up.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door opener
Can you hook up sensors to an older craftsman garage door that never had them?
Jun 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
65 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
