Question about Dishwashers
C3 error on a 2230 ge potscrubber dishwasher. Reset it, turned it back on, then get C4 error. Continue to get errors and dishwasher won't drain
  • 114 Answers
SOURCE: ge potscrubber 640 dishwasher
You probably have a restricted water inlet valve. It is not allowing the proper rate of flow for the allotted time, therefore not giving enough water to create the proper velocity to reach the top rack.
Posted on Feb 19, 2008
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
billfrye
SOURCE: Dishwasher Timer won't advance
my timer has stopped functioning altogether. it was first an intermittent problem, but is now 100%.
Posted on Jan 02, 2009
localwonder
  • 6784 Answers
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
SOURCE: ge potscrubber dishwasher will not
Had the same problem with my dishwasher. Took it appart thinking that something was plugging the drain but there wasn't anything. Turns out the cylinoid that has the hook coming out of it to control the flap for the ejection of the water is broken. When looking at your pump, you should see a small flapper valve on the exterior of the pump hooked up to a small cylinoid that when accivated flips a flap in the pump to eject the water out of it instead of letting it circulate in the unit. This is an easy part to replace, but for me, hard to find since my potscrubber is so old. Hopefully your units are newer and you can find this part at your local appliance shop.
Posted on Oct 12, 2009
Ge potscrubber dishwasher #2230
try removing the bottom panel with washer off look for small fan on motor turn to make sure it is turning free. This happens a lot with the snowbirds in Fl. Simple fix.
May 15, 2014 | Dishwashers
My GE Potscrubber 2230 is not heating the water in the dishwasher. The water at the sink is hot but when I ope the dishwasher, the water is closed. Sooo, it's not cleaning the dishes. Is there something...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 18, 2010 | Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
