Question about La Crosse K2-100 Wrist Watch
I dont know what to do
My grandmother bought me this watch and i set the time then it reset its selt. (like when you hold all the buttons) and it done that every time i set it, and somtimes i didnt. so i dont know wut to do...
Check this website I think it will help you with your peoblem If not post it again and I'll try and find some other help http://www.geocities.com/gregclep/clocks/lcwatch.html
Posted on Jul 03, 2007
SOURCE:
How do you set a popart pop-693ad watch
Ok, it took awhile to remember, but to reset the analog time or the day or anything else, first push the "mode" button which is at the 8:00 position on the side of the watch, 3 times. The first push will bring up the stopwatch, the 2nd push will change the alarm time, the 3rd push will highlight the seconds which on the watch face is at the 6:00 position. Release after the 3rd push and push the "reset" button which is located at the 4:00 position. It will start flashing the hour first. If that is what you need to change, then push the "start" button which is at the 2:00 position. Either keep pushing the start button to set the hour or hold the button in if you have more than a couple of hours to change. When that is done, if you need to change the minutes, push the "reset" button again and the minutes should be highlighted and do the same thing with the "start" button until you have the minutes set where you want. When you are done changing whichever thing needs to be set, including the alarm time, push the "mode" button and everything will stay set. This is for the Pop Art 693 AD watch which if you buy through ebay, it's an awesome watch with dual analog/digital time displays, etc. it comes with no instructions. If all else fails, go to the jewelry counter at a Walmart and hopefully the worker there can help. We found that once with a different watch. I hope this helps everyone!!
Nov 13, 2012 | Watches
I bought a pink and purple xhilaration watch from target, on the back of it, it saysTGXL103PNK, CHINA, MODULE, CR2032, 0712, AWC............ it has to two side buttons on the left side and one on the right...
press on the MR/C (set) button. This button is located on the calculator buttons area of the watch. Hold this button until the date begins to blink. you select the numbers you want to set the date and time to by pressing the correspondent numbers on the key pad. once the date and time is set press the enter key.
Oct 30, 2012 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
    It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
    If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
    Sep 21, 2009 | DKNY Watches
    Lost instructions to set my solo digital watch
    I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
    Jan 11, 2009 | Bulova Watch
    Prospirit watch
    in order to SHUT OFF THE ALARM:
    go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
    May 15, 2008 | Watches
    How to set a nike triax watch
    Press and hold in the mode button the seconds should start to flash.
    Press top right button to select hour.
    Press set button to advance hour.
    Press top right button to select minutes.
    Press set button to advance minutes.
    Repeat this for the month/dte/dy/yr
    Press mode button when done
    Mar 09, 2008 | Watches
    I dont know how to set the time and date on my watch{arnette model ar 2041}
    do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
    Jan 15, 2008 | Watches
    Columbia Watch CL-5030
    Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
    Dec 25, 2007 | Columbia All Sport Digital watch
    La Crosse K2-100 Wrist Watch Logo
    118 people viewed this question
    Top La Crosse Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Ekse
    Are you a La Crosse Watch Expert? Answer questions, earn points and help others
