Question about Cameras
How can I repair The Fujifilm F600 exr lcd blackout problem
My Fuji film Fine Pix F600 EXR LCD is not working,it can still take pictures, also can zoom in and out. Everything else is OK but only the 3 inch LCD is blacked out. So what should I do?
    Sergeant:
  • 321 Answers
LCD circuit belt is crack take it to Serv.
Posted on Jan 10, 2013
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
Steve5
  • 423 Answers
SOURCE: Fuji Finepix S9600 - Photography mode doesn't work
Sounds like the CCD (main image sensor) is dead. It should be covered under warranty. It doesn't sound like there is anything you've done, or can do to rectify it. Get it in to a Fuji service center with your warranty/receipts.
Posted on Sep 27, 2009
Testimonial: "Thanks, Steve. I took it to an authorized service center and the CCD sensor was indeed dead. Warranty covered! Thanks again!"
Steve5
  • 423 Answers
SOURCE: fuji fine pix 5000
In all these cases it appears the CCD (image recording circuit) has absorbed tiny amounts of moisture. These circuits are known to have been manufactured improperly. The only solution is replacement of major circuitry.
http://www.letsgodigital.org/en/news/articles/story_4719.html
Here's a link to some information regarding these problems.
Posted on Jan 22, 2008
  • 244 Answers
SOURCE: Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
Posted on Mar 08, 2009
lock123
  • 6831 Answers
SOURCE: lens control error message comes
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 26, 2011
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
Factory reset
there is only a normal reset mode, it is on page 93 of the manual. The manual is free on the fujifilm site. Just google for fujifilm and HS20 EXR manual.
Sep 26, 2013 | FUJIFILM HS20 EXR Digital Camera
Fujifilm Finepix HS25 EXR screen replacement
Your best bet is going to be E-Bay, search your camera make and model under parts and you will find just what you are looking for.
Jan 23, 2013 | Fujifilm FinePix HS25 EXR 16MP, 1080p 30X...
F80exr does not display date /time on review or prints
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Oct 30, 2012 | FUJIFILM F80 EXR/F85 EXR Digital Camera
Where can I find a manual for my Fuji HS 20 on the net?
You can download the manual from the manufacturer's web site at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_hs20exr_manual_01.pdf
Jun 15, 2011 | FUJIFILM HS20 EXR Digital Camera
My Fuji Finepix F550 camera cann't receive GPS signal in China,but it is OK in Germany.I want to know the reason.By the way my GPS navigator works well in China.
China regards all pictures taken in the country tagged with GPS metadata to be "spy" related. Therefore, they have blocked those capabilities in digital cameras.
Apr 22, 2011 | FUJIFILM FinePix F550 EXR Digital Camera
Ihave a fine pix z20. The LCD screen is not working. The camera still takes pictures fine and the card prints the pics fine but the screen is just white with a grey line through it. I forgot to register...
If you still have few days warranty, call Fuji at 1-800-800-3854 , select option 1 and register your product, or check the website. They will tell you if the camera is still on warranty.
Here also US website.
Fujifilm: Support & Contact Center
If you leave outside US see fuji website for contact:
Home | Fujifilm Global
FUJIFILM Australia
FUJIFILM Europe
Jul 27, 2009 | Fuji Cameras
Cameras Logo
148 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
