I can not get my Asus Eee Pad TF101 to charge at all
I have tried the original cord and a new cord with the same results. . . nothing for either the Eee Pad or docking unit. No little red light or anything.
  • 7,627 Answers
Try another AC outlet. Maybe the AC jack has been damaged, due to pulling on the cord? Maybe the battery is dead? The cord you used is damaged, Was the other cord you tried the EXACT same power spec? If not it could fry a component.
Posted on Jan 10, 2013
  • 45 Answers
SOURCE: Asus eee 901 will not start
Try this - open the laptop up and on the motherboard there should be a small round flat battery (bios/cmos) take this out and leave it out for atleast 20 minutes then put it back in and startup the laptop. Hope it helps, leave me a comment to let me know!
Posted on Aug 10, 2009
  • 32 Answers
SOURCE: my asus eee pc series keeps freezing and nothing
most likely you have contracted a virus and need to reinstall windows. the only other possibility is a major hardware issue
Posted on Dec 28, 2009
  • 20 Answers
SOURCE: My eee pc wont recognize that it is plugged in.
Usualy this is a battery fault.
If the laptop remains on ac mode without battery try to replace the battery.
Posted on Mar 10, 2010
Joed911
  • 4338 Answers
SOURCE: I have an ASUS eee netbook. Recently the power
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Posted on Nov 30, 2010
joegoldman
  • 335 Answers
SOURCE: ASUS EEE PC 1008P the system
Maybe try cleaning the battery contacts on the netbook. If it happens with both batteries, then it may just be bad contact between the battery and the laptop. An emery board, or a small piece of fine sandpaper can be used to clean the contacts on the netbook. Clean both sides of the contacts - do it gently as you don't want to sand down the metal, you just want to clean off any oxidization or corrosion on the terminals. If this doesn't help, it may be a bad charging circuit on the board (new netbook). You could also try charging with a different a/c adapter and see if the problem persists.
Hope this helps!
Joe
Posted on Jun 04, 2011
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Mar 05, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Change front glass on tf101
this is the cheapest replacement part i could find Digitizer for Asus TF101 Eee Pad Transformer Front Glass Touch Screen...
replacing it yourself is not extremely difficult but it's not a walk in the park. however, having it repaired by someone else is probably not very cost effective since theyll probably charge upwards of 100. you decide, though. i hope i was helpful and good luck!
Feb 01, 2014 | Computers & Internet
My asus tf101 is stuck in clock work orange mode how do i fix
Go to asus site there is a new flash for tf101, download and install
Jan 22, 2014 | ASUS Eee Pad Transformer TF101-A1 10.1...
IS ASUS EEE PAD TRANSFORMER COMPATABLE WITH ATT
I know that the TF300 is compatible with AT&T but I think that the TF101 is only wireless capable. If you really want AT&T you could purchase a mobile hotspot from them and connect using that.
Dec 11, 2012 | ASUS Eee Pad TF101B1 Tablet
Tablet wont turn on
You will have to to send it in. There is not really much you can do accept checking that the battery is right in. Maby just take it out and put it back in.
Go chat with an asus technical service here and see if they can assist you on maby power resetting it
http://support.asus.com/diagnosis/selfdiagnostic.aspx?SLanguage=en
Hope this helps.
Aug 27, 2012 | ASUS Refurb] Eee Pad Trans. TF101-B1 10.1"...
ASUS Tablet TF101 Wont Charge
batteries do not last forever get it replaced by a computer shop
Jan 05, 2018 | ASUS Eee Pad Transformer TF101A1 Tablet...
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
