Question about Quatech SSU-100 Serial Adapter
Usb2.0 to rs232 convertor suports rs232 serial interface db9
Have usb device and disc no driver can not install
  • ebrant95 Jan 22, 2009
    i need help with my usb port
Plaese help me with my usb
Posted on Jan 22, 2009
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
How do i upload test results from my lt8600t tester to my PC. I have USB ports in my PC no serial port. What do i need?
Ah, yes, I too used Waveteks back in the old days and I still have old PCs with serial cards in them which typically came with the PC. They were never really all that expensive to replace.
Anyway, newer PCs typically lack serial (DB9) ports/cards; and simply using a USB-to-DB9 adapter on a device designed to use a DB9 interface won't help the PC "find" the unit attached to it. Theres no easy "plug-and-play" there. The PC wants to have drivers for the unit installed manually, then with some luck something will show up in Device Manager. Conversely the old Wavetek wants to see X number of pins, etc. or it will assume somethings wrong.
There are a few "USB to RS-232 DB9 Serial Drivers" (e.g. "Prolific" brand) to be downloaded here and there, I can't tell how effective they are, depending on your PC hardware/software.
Feb 16, 2015 | Wavetek Acterna LT 8600T Network Testing...
Windows 7 usb driver
make sure the db9 rs232 cable is the correct type.
be sure to set the correct parity and bit stops and baud rate.
you may require a driver if windows 7 isn't already set up for serial connections. http://myaccount.flukenetworks.com/fnet/en-us/supportAndDownloads/KB/Copper-Testing/scanlink/How_do_I_export_Scanlink_data_to_a_text_file
see the link for the how to connect.
I would recommend a usb to serial adapter and make sure to get one with the drivers for windows 7.
Oct 09, 2013 | Fluke Networks CertiFiber (8240-04)...
I need a 15 pin serial cable to USB adapter. Having trouble locating one :)
Here: http://images.google.com/imgres?imgurl=http://www.uxsight.com/product/images/c/en/usb-rs232-db9-9pin-serial-cable-db25-25pin-parallel-adapter-com-xs0065090316c.jpg&imgrefurl=http://www.uxsight.com/product/29236/usb-rs232-db9-9pin-serial-cable-db25-25pin-parallel-adapter-com.html&usg=__WqWw10iNkCZ7AwioDUW5DOvnHwI=&h=286&w=594&sz=37&hl=en&start=4&sig2=SqUqch5MFMdtlYcPZgGOkg&um=1&itbs=1&tbnid=MtLIazQSQfuOUM:&tbnh=65&tbnw=135&prev=/images%3Fq%3D15%2Bpin%2Bserial%2Bcable%2Bto%2Busb%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26sa%3DN%26rls%3Dorg.mozilla:en-US:official%26tbs%3Disch:1&ei=j7CJS4zBFIaVtgeDxIyZDw
Feb 15, 2010 | Logitech WingMan Extreme Digital 3D...
How to interface a furuno 1833c navnet to a usb port and how to download waypoints to my pc.I have the older 9 pin pc cable and a usb adapter cable.Looking for usb drivers and software to make it work.
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Jan 11, 2010 | Furuno 1833C/NT GPS Receiver
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
Quatech SSU-100 Serial Adapter Logo
6,118 people viewed this question
Top Quatech Computers & Internet Experts
David Payne
David Payne
Are you a Quatech Computer and Internet Expert? Answer questions, earn points and help others
