Question about FocalPrice iPazzPort KP-810-16 2.4G RF Wireless 82-Key Keyboard & Air Mouse Black
Ipazzport curser goes in opposite direction from where it should
When I move port up curser moves down and vice verse.
Cant get the mower to move , grinding sound when i try . when jaqcked up off the ground i can turn rear wheel the other goes inthe opposite direction .
With both wheels off the ground they will move in opposite directions. That is the differential gear working correctly. Check there is nothing stuck in any of the drive belts, shafts, pulleys or wheels, (twigs, stones, dead squirrels, etc.) . Move each component in turn and see where the noise is coming from. Once you know what's causing the noise you can fix it. Good luck.
Aug 13, 2014 | Husqvarna Garden
Our Nelson tractor sprinkler is going backwards! How do we correct this?
You need to aim the rotary arms in the opposite direction. If the spray pattern is spinning clockwise, then you need to make it spin counter-clockwise or vice-versa. You do this by adjusting each of the 2 arms 180 degrees so that the jet stream spurts right instead of left (or left instead of right). Remember, the spray arms are connected to a gear box, and the gear box turns the wheels. Your wheels are moving in the wrong direction because the gears are moving in the wrong direction because the spray arms are spinning in the wrong direction because they are aimed in the wrong direction.
Jul 20, 2011 | Nelson Sprinkler: Traveling Tractor
Wireless controller up and down moves in opposite
To fix your controller , go to the "Options" menu in C.O.D. and select "Controller," then click on "Normal". It should be set on "Invert" right now. You want to change it to "Normal"
Oct 12, 2009 | Microsoft Xbox 360 Controller
360 controller moves in opposite directions
Your controls are inverted you just have to go to the controllers and press invert Y-axis
Jun 17, 2009 | Microsoft Xbox 360 Controller
Sony vaio touch pad not working.
i have sony vaio vgn-sz58gn model laptop with windows xp installed. but on touchpad whenever i move cursor to up, it goes to down. if u move cursor to down, it goes up. can you provide me solution pls for that?
Awaiting
Apr 20, 2009 | Computers & Internet
Mouse direction
Dear Stephenson,
Please check the mouse's ball properly, and check for a to z, i mean, from top to bottom. Further, i am sure that it might got damage, please check the cursor's moment, wireline from mouse to cpu, ball rotation etc. you will get a solution, if you set right the ball, wire line, etc.
Thank you for contacting fixya team.
Warm regards.
Sep 11, 2008 | Packard Bell Mosuk 3D U-Shape...
Wii Remote Problem
oh no!! i suggest that have to reformat your console. Maybe, some of its drivers tend to malfunction..
Feb 05, 2008 | Nintendo Wii Console
Inverted vertical scrolling
did u download latest driver form website maker site dont use cd
Jan 28, 2008 | Microsoft Wireless Laser Desktop 4000...
FocalPrice iPazzPort KP-810-16 2.4G RF Wireless 82-Key Keyboard & Air Mouse Black Logo
43 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
