Keep getting a black screen, but computer is on
Computer comes on, but get a black screen, can not see the screen come on.
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jan 10, 2013
When i turn my computer on the screen is black for awile then it comes on where i can see my screen saver why does it do this
Turn the computer off.
Turn the computer on,
and keep pressing the 'F8' key until you see a "start-up" menu.
Choose "Start in Safe Mode".
Does the screen now look normal?
If so, set the "screen-resolution" to 800-by-600.
Then shutdown and restart.
Feb 09, 2015 | Dell Computers & Internet
My screen goes blank after all disk top come up can you help i have a travelmat 2300 acer lap top
Looks like an issue with either display or system is overheating. Please try the below steps.
1. Shut down the computer
2. Keep on tapping F8 key as us press the Power button to turn on the computer.
3. Choose safe mode using the arrow keys on the keyboard and hit Enter Key
4. Stay on the safe mode to see if the screen is going blank, if not
5. A system restore should help to fix the issue. Let me know!
Thanks!
Anil.B.R
Oct 02, 2013 | Acer TravelMate Computers & Internet
I am using a lenovo all in one ideacentre computer. The screen goes black for a few seconds then comes back
The screen goes black then comes back. When it comes back are you able to use the computer without any problems? When does this happen? Most times during the boot process the screen will fade in and out.
If this is not happening when you boot the system it's possible that your lcd screen might be going bad so keep an eye on it.
May 31, 2012 | Computers & Internet
How do I restore my pc back to factory settingg
1) Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  • 2) Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.
  • 3) Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
  • OR
    As soon as your computer is turning on press the F10 key and it will take you to the system recovery screen, click on the advanced option and click Destructive recovery and click next. WARNING: before doing this backup anything on your computer you want to keep pictures,videos,music etc.. this will delete everything that did not come pre-loaded from the factory, so if you have pictures of Aunt Fae's Class reunion you should probably back those up if you wanna keep them.
    To keep your PC fresh and optimize it to best performance use system utility software RegInOut
    Dec 15, 2011 | HP Computers & Internet
    I have a gateway nv5470u,it picked up virurs and went blank,,it would not come on,then one day i hit the turn on button,it come on a blank screen with a white line uptop to the lleft...
    That means that the hard drive is not detected properly on the computer.
    Start the computer and keep tapping F2.
    You will get a setup utility.
    Press F9 and hit ENTER.
    Press F10 and hit ENTER.
    Now restart the computer.
    If u still have the blinking cursor on that black screen, u need to check your hard drive.
    If u are gettng some other error in windows or just a black screen, try doing recovery.
    Recovery will wipe off all your datas in the computer.
    For doing it, keep tapping Alt+F10 as soon as u turn on the computer.
    If u are succesful, it will give a message that windows is loading files.
    Just follow the prompts.
    Keep me posted on the status of the issue.
    If that helps, dont forget to rate me.
    Nov 09, 2010 | Computers & Internet
    Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
    are you using windows? just reinstall your operating system, this may keep it back to normal
    Jul 15, 2009 | Dell Inspiron 1525 Laptop Jet Black
    Black screen
    Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
    May 27, 2009 | ViewSonic VX2235wm LCD Monitor
    Monitor keep going to black screen while viewing.
    Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
    A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
    Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
    Help please
    Reset the player first, (manual will tell you how)
    if that fails
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    May 27, 2008 | Audio Players & Recorders
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
