Question about GE Profile JTP18 Electric Single Oven
GE oven only heats up to 300 then shuts off
We have a ge oven jcb 968 that only will heat up to 300 then shuts itself off .Both top and bottom elements apear to be working. on broil the top element got red hot then it shut itself off .No error codes appear at all. Since new ,15 months it seems to have slowly lost tempature and now it has begun to shut itself off.
  • ted75 Jan 28, 2009
    • Oven shuts itself off. Started at 400 now at lower temperatures
    • Temperature displayed on oven is higher that real temperature
  • 59 Answers
Just a thought but maby the
tempature sensure has gone bad
Posted on Jan 21, 2009
SOURCE:
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
How do I replace the bottom element of my GE oven?
Hundreds of GE ovens, so can't give procedure, but problem is not necessarily the element - could be switch, connection to element, etc. Google GE (model #) lower element not heating.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 27, 2016 | GE Ovens
I need top heating element
to be honest cost more usually to fix than buy a new one but your local appliance repair shop is best bet
Jan 17, 2015 | GE Ovens
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Oven popped and smoked
seatie, as long as you have the breaker off to the oven you should be o.k. Sounds like something shorted to the oven cabinet. It could be the terminal connection on the heating element itself. The main board could of shorted out. Without being there it's hard to tell, but you will be fine until GE arrives as long as the breaker to the oven is off. Catriver.
Sep 20, 2007 | GE Profile JTP56 Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
589 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
