Question about Mach Speed Trio 7" Trio Stealth Pro Tablet - 87837
My trio tablet will not turn on but the red light is on.....
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
How do I get trio watchdog off my trio axs4g tablet locked in demo mode !
Dc, I know very little about axs4g so I did a google search and It looks like you should delete the app watchdog. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Take trio AXS 4G OUT od demo mode My trio AXS 4G somehow is in demo mode...
Trio Tablet Support
Jun 14, 2015 | Tablets & eReaders
Triomp3
Do a hard reset by using a push pin to insert in the hole. I did not lose my information. OR you can use a usb cord to attach your Trio to a computer and extract your information from the Trio first.
Jul 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
Trio tablet screen stuck on trio logo
hi try doing it this way.all data will be lost...
Jul 07, 2017 | Tablets & eReaders
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Mach Speed Trio 7" Trio Stealth Pro Tablet - 87837 Logo
97 people viewed this question
Top Mach Speed Trio Computers & Internet Experts
k24674
juanmireles1
Tom Chichester
Are you a Mach Speed Trio Computer and Internet Expert? Answer questions, earn points and help others
