Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Rear Projection TV shuts down after a few minutes.
Zenith Z52SZ80 will shut down after being on for 15 minutes. We wait a few minutes and turn it back on. It shuts down again after less minutes. We repeat this and it keep shutting down. Lamp indicator is orange indicating the lamp is reaching the end of its life and needs to be replaced. Is it the lamp, only, that needs replacing or is the ballast also a problem? What are the part numbers for the lamp and ballast?
Thanks.
  • feltus Feb 05, 2009
    How do I access the lamp or know which type to get ?
  • 59 Answers
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Posted on Jan 21, 2009
DLP keeps shutting off
Check Lamp Fan or Fans and it could be that the Lamp is going out.
Oct 01, 2012 | Zenith Z52SZ80 TV
Tv went off and wont come back on just had bulb replaced fan is on but no power indacater on front
OPPS!
You may have damaged the lamp or the ballast that drives the lamp.
Confirm the model and brand to me:
All sets that use a lamp warn you to if you turn set off NOT to unplug it for several minutes until the fans in set all shut off.
What can and does happen is when set turned off the fans continue (especially the one on the lamp) to run until the lamp cools down to a specific temperature---unplug it before that and the lamp can instantly be damaged or even destroyed.
Mar 27, 2012 | Zenith Z52SZ80 TV
My car will start but after about 15-20 minutes of driving, the car will completly turn off...i have to wait for the car to cool down for about 30 minutes before i can restart again and drive it.. If i...
if light on dash is on, then it sounds like a bad crank sensor. shuts off while driving down road, then will not start for about 15 minutes. heres more causes:: car shuts off when tempurature gets to normal-- low coolant, failing coolant tempurature sensor, air in water pump, failed radiator fan, it takes 10 to 15 minutes for a car to warm up. check or replace coolant temp. sensor if above is ok. have a good day !
May 04, 2011 | 1995 Geo Prizm
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
333 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
