I have a 32 inch element ELCFW327 lcd 720p tv and on ther right hand side of the screen about 4 inches in i have two small vertical lines going all the way down the screen from top to bottom a hair apart and now some have appeared on the other side about 8 inches in. What can i do to fix it?
SOURCE: Vertical line on TV
usualy this problem is cause by the lcd drive board.
Posted on Oct 24, 2007
SOURCE: my tv is hitachi 55pd plasma
Hitachi did in fact stand behind their product and resolved the problem. My hats off to them! Panel was replaced due to faulty ribbon cable supplying signal from one of the drivers. Unfortunately for my specific issue there wasno other solution as the ribbon cable in sealed inside the glass panel.
Posted on Jan 17, 2008
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Posted on Oct 16, 2010
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
  • 225 Answers
SOURCE: Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Posted on Jan 08, 2009
Fix vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
Samsung lcd 32 inch tv has vertical lines in color about 4 inches wide all over the screen and it has no picture but it has audio
Only boards are sold and no parts- a 32 inch may not have even the boards or be cost effective to repair----suspect main board here.
Aug 26, 2012 | LG 42LC2D 42 in. LCD HDTV
Philips 32 inch LCD has colored vertical lines when powered on.
this sounds like a screen fault to me
try grabbing both sides of the tv and giving it a twist
this will either give you more lines or make ur lines go away if this happens u need a new screen
May 15, 2012 | Philips 32PFL3505D 32 in LCD TV
When I turn on tv, i get blue light at bottom but no sound, no picture. I tried to get to the menu because it is always in use for video games but no luck. Before this occurred, the tv had a 4 inch wide...
You probably have some bad electrolytic capacitors on the power supply module. The caps will be bulged or mushroomed at the top rather than flat if they need to be replaced. Parts are very inexpensive. I've fixed many of these sets by replacing bulged caps on the power supply for having same symptom of yours. That would be the first place I would start. A repair shop would probably get between $100-$150 to replace these parts if you wanted go that route.
Jul 30, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Jan 08, 2009 | Televison & Video
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
