I have a Philips php-x17 monitor - this has the strangest connection lead into my PC - can anyone tell me what connection lead it is? It is not a VGA or DVI or HDMI - Help? it used to connect to my
I have a Philips php-x17 monitor - this has the strangest connection lead into my PC - can anyone tell me what connection lead it is? It is not a VGA or DVI or HDMI - Help? it used to connect to my PC - but I need an adaptor now to adapt this connection to a VGA port and I need to know what it is!! help!
  • Colin Wallace
    Colin Wallace Apr 01, 2014
    I have one of these its a DVI-I 24+5 connector, and I bought this to take it to vga, DVI-I Female Analog 24+5Pin to VGA Male 15Pin Connector Adapter Converter for PC
  • 27,725 Answers
Can you supply a picture or state how many pins the plug has
you can get many adapters to fit almost anything on ebay
http://www.ebay.com.au/itm/DVI-Male-To-HDMI-Female-Plug-Converter-Adapter-for-HDTV-/181010959825?pt=AU_CablesConnectors&hash=item2a25180dd1 AU $2.95 free postage This is not the right one for you its only a guide
Hope this helps.
Posted on Jan 09, 2013
BEERbrooklyn
  • 101 Answers
SOURCE: connecting a dvi-d cable from dvi-i graphics card to lcd monitor
i use a dvi connection on my computer.my lcd has many types of connectiond.i have to go to my menu on the lcd and choose what connection i using.maybe you have to do the same.
Posted on Feb 21, 2008
ericvb2005
  • 194 Answers
SOURCE: No signal to monitor
if u have a two VGA output in ur PC..try to use the build in VGA port...if doesn't appear... Try the one VGA port
Posted on Oct 18, 2009
vanherringto
  • 1738 Answers
SOURCE: I have a dell dimension 8400. The graphics card
You may have left out a couple of steps.
Now, you need to configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab.
The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate.
If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Posted on Feb 03, 2010
lothar96
  • 11 Answers
SOURCE: can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Posted on Mar 29, 2010
  • 19 Answers
SOURCE: i have HP Pro3000MT, and
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Posted on Apr 02, 2011
Dell XPS 400 monitor dont show
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead. Hope this helps.
Jan 09, 2013 | Dell XPS 400 PC Desktop
Monitors green light comes on but can't get picture
Dec 29, 2012 | Compaq Presario 5000 PC Desktop
My computer starts up but the screen sa ys no signal
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
If its a 40 pin flat ribbon type it will be the first to fail.
Even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error.
if you remove your graphics check the socket to make sure its dust free.
Check the VGA cable connection running from the computer to the monitor.
This cable must be completely inserted into both VGA connection ports, otherwise the video signal is not going to reach the display.
Disconnect the VGA cable from the computer and monitor, then look at the metal connectors on both ends.
If you are missing connection pins, the video signal is not going to transfer between hardware correctly.
To fix this problem, you must obtain a new VGA cable (at any computer or electronics store) to send the video signal.
Examine the power connection on the monitor.
If the monitor is not receiving power, it is not going to turn on.
Turn off the monitor for a few minutes, then power it back on.
Like other computer hardware, the monitor may not initially turn on correctly.
Move the mouse and press the "Enter" key on the computer keyboard.
If the computer is in sleep mode, the monitor is going to appear as if it does not have any display.
Hope this helps.
Nov 22, 2012 | E-Machines eMachines Desktop PC
Where can I get the cable that runs from the monitor to the pc to fit a phillips php-x17 monitor?
The Only way as far as i can tell, if you have a cable that connects to either the Monitor or the PC is to try a adapter . Heres a Link you can check for a adapter its >> http://www.firefold.com/HDMI-Adapters-C1205.aspx, Thats all i can come up with for you. Hope this helps you find what you need. Good Day to Ya.
Feb 20, 2012 | Computers & Internet
Unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Good luck and thanks for using Fixya!!
Feb 12, 2009 | HP Pavilion dv2000t Notebook
CHANGEING MONITORS
Hi Laura and welcome to FixYa!
Yes, you should be able to change your monitor. You will notice that if you unplug your monitor's cable from the back of your computer, you will see an adapter that looks like the one below (called VGA).
I can't seem to find the specs on the new monitor you mentioned, but most new LCDs (flat screens) have DVI cables, which look like the picture below.
Don't worry, its an easy fix. Go down to your local electronic store and ask for a "VGA to DVI converter". It will look like the one in the picture below. Mine cost me about $8 USD.
I hope this helps. If you have any questions, do not hesitate to ask.
Happy Holidays,
-TJ
Dec 16, 2008 | Philips 170S4FB 17" LCD Monitor
Need the philips manual for:- Model No 700P Product No PHP-X17 Ser No F9V1690229429
If it is any help i think that is made by Sansung. I couldnt find anything on the number you provided from Philps. But Samsung does make a 700p that got sold to lots of other compaies like Dell,Gateway,Ect.
Feb 28, 2008 | Computers & Internet
Connect saround sound dvd to pc
does anyone know the remote control commands , i just bought this from a friend who lost the remote.
thanks
Oct 01, 2007 | Philips MX5060D System
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
