Question about Apple MacBook Air
I changed my macbook screen, and the backlight now will not work. Everything else works fine, just no light. My real question is what voltage should be coming from the inverter board. I read no AC or DC voltage at the output. The computer was dropped, the screen broken. I also need to know thw input voltages on the inverter.
  • 502 Answers
This could be a backlight issue, an inverter issue or a logic board issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Maybe the new screen was not wrapped right when it was shipped, that can easily break the backlight bulb. make sure you connected the inverter to the white and pink wires correctly. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. I work for Mac Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Posted on May 27, 2009
  • Steven Sosnin
    Steven Sosnin Nov 19, 2013
    LOL takes you 1-2 hours? its a 20 min fix for a trained tech.
  • Steven Sosnin
    but yes, it is difficult so i suggest getting some practice first. just buy a cracked complete lcd for like $30-$40 on ebay and replace the ccfl bulb (DO NOT SUGGEST TO INEXPERIENCED TECHS) and replace the inverter and the inverter power cable. It could also be a logicboard issue if all else fails. Under the inverter connector on the motherboard, the connection point wears off or builds residue in which case you clean it very carefully and/or you can melt some solder to the point after cleaning it ONLY IF NECESSARY (ALSO NOT RECOMMENDED FOR INEXPERIENCED TECHS). Unless, of course, you have dough to blow on a new MB.
  • 40 Answers
Apple doesn't provide voltage information for the Inverter Board.
If you are getting external video then check to see if there is a dim (un-backlit) image on the display to ensure it is a backlight problem. If so then the chances are good you have a failed inverter board.
Posted on Mar 01, 2009
How do I change the backlight for the jandy control panel
go into the setup you can change the backlight options there
Sep 11, 2014 | Jandy Aqualink Rs4 One Touch Control...
Black screen with flashing horizontal lines
You may have a bad backlight screen power supply board and that is usually mounted in the bottom part of the screen right behind the front bezel. This supply's high voltage to the backlight tube that lights the screen. This is kind of like a small florescent tube that uses high voltage to fire the backlight and is a common failure point in laptop screens. Easy to fix, just pop the front bezel off and the module will be in the center bottom section of the screen. Do a YouTube search on how to disassemble your model's screen and the parts can be found on Ebay. Good luck.
Apr 14, 2017 | Compaq Computers & Internet
Cable to Display from motherboard has change and i get a now backlight image on screen, the book goes fine on micro dvi to dvi and i gor the camera working too. What is the problem ? the screen the...
If you can see the LED back lights then the screen is at fault. If you have a logo permanently etched onto the screen then this is also going to need a new display.
(Have a Google around for screen burn-in) If the fault is temperamental try moving the display back and forth, if you have issues then this means it is the cable running from the motherboard to the display.
Mar 01, 2011 | Apple MacBook Air
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
MacBook 13" starts but screen is barely visible. Tried System Preferences - already on brightest setting. Works fine otherwise. Any ideas? Capt. Dave
could be your inverter board, whitch controls the backlight. I could very well be the backlight as well, but that is less likely. Inverter boards are not all too expensive, and if you are knoledgable with laptops, i would say doit yourself, but if you have any doubts, take it to apple, sur it will cost more, but it is the safet bet.
Jan 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Macbook chip shim
Thias can also come from a dead hard drive, or a dead backlight (screen).
The best test would be to plug an external monitor to see if something shows up. If yes, that would mean that the backlight doesn't work anymore. If not, then you have an other hardware problem (motherboard, hard drive).
You can check if the hard disk is the problem by removing it. You should then see a flashing question mark and the screen on.
Keep in touch ;)
Jun 25, 2009 | Apple MacBook Pro Notebook
Screen is dark or dead on my 17" Macbook Pro
This could be a backlight issue, a board issue or an inverter issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, you'll most likely have to google for guides that show you exactly how to replace the backlight or bring it in for repairs.I work for Mac Repair NYC and i have to fix this problem a lot.
May 21, 2009 | Apple MacBook Pro Notebook
Apple MacBook Air Logo
856 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
