Question about Sony CMT-CPX11 CD Shelf System
Stuck in standby
My system is stuck in standby. Have tried switching off and on at the mains but no good. Any body any ideas?
  • 1 more comment
  • Rob Backhouse Jul 02, 2007
    I have tried the factory reset and tried it with and without speakers. Unfortunately neither fixed the problem.
    Apologies for giving negative feedback to the first two advisors. This is my first time on FixYa and I can't see how to change the feedback!
  • Rob Backhouse Jul 24, 2007
    Tried the reset but still no good. Any ideas which components to change first?
  • 705 Answers
I think Noggin is on the right lines for unit but I think in his description he forgot to mention that you need to press 1 Disconnect the mains lead. 2 Reconnect the mains lead. 3 Press power to turn on the system. 4 Press TAPE [], CD [] and power on the unit. The system is reset to the factory settings. You should set the settings you made, such as the preset stations, clock, and timer.
Posted on Jul 02, 2007
  • Inky Fingers
    Inky Fingers Jul 02, 2007
    The Button sequence is described as follows in the manual:
  • 944 Answers
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
  • Anonymous Jul 02, 2007
    if you wish to change the rating for a premium solution, please just click "report abuse" and describe what you need to change.
    Sorry didn't work, leave the problem rated unsolved for a while to see if anyone else has any ideas.
    I will search around again for any possible solutions in the next couple of days, but i Think the main control board is probably fried if the reset/speakers didn't change anything
    President:
  • 3,130 Answers
You can also try and disconnect the speakers and see if the unit comes on. If it does, connect up the speakers till the unit shuts down. That will be the bad speaker. you will need to have the bad speaker replaced or repaired. If the unit will not reset by unplugging it and replugging the main power, there is a problem in the main amp or the main power supply. Good Luck
  • Larry  Dillon
    Larry Dillon Jul 03, 2007
    If the reset does not work,or if taking the speakers off,the unit has a power supply or audio output problem and will need a shop to have a look if you have no solid state repair experience.
SOURCE:
Tdk cd player stereo system stuck on standby. the red standby light is on the only thing I have done since it was last working yester day is remove and reinsert the speakers from the unit.
Try resetting by leaving disconnected completely from the mains for 2mins. Throughout this time frame keep your finger pressed on the power/standby button.
Feb 18, 2016 | TDK Audio Players & Recorders
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
Feb 15, 2013 | LG MKJ42519615 Remote Control
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
Sony CMT-CPX11 CD Shelf System Logo
893 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
