Question about Microwave Ovens
How to replace the element in a gino d'acampo halogen oven
2 Suggested Answers
  • 8404 Answers
SOURCE: I need to replace the
I am not finding much joy for your question. Please consider the remarks of these other users: http://www.fixya.com/support/t243065-halogen_light_heater - http://www.fixya.com/support/t866323-need_user_manual.
Here is a large parts house where you may inquire: http://www.appliance-parts-experts.com/Appliance-Parts_c_843.html -
You can find a manual here: http://kitchen.manualsonline.com/manuals/mfg/westinghouse/wst3028.html
When you receive this response, there will be several advertisers also on the page. You may consider contacting one of them directly for your parts. FixYa.com is not a parts supply nor a repair service.
One last idea, is there an appliance repair station in your town? Have yo spoken with anyone there? Mayge you should check that out.
As one of the other commenter's said, you may be better off replacing the unit considering the difficulty of not only getting the parts but also installing them once you do get them.
I'm sorry I couldn't be of more assistance for your trouble.
Thank you for considering FixYa.com
Posted on Feb 28, 2011
Where do I get replacement halogen blub
Hi Sandie
You are asking about a Microwave oven...right?
They usually don't use halogen bulbs. Just a standard incandescent bulb. Don't need super bright in Microwave oven.
Take the bulb out and note the Voltage, Wattage and Shape & Size of the base. Bayonet or Screw etc. some details may be stamped on bulb.
Replacements can be had from many sources. Hardware / Electronics... depends where you are.
If the bulb is halogen for a vehicle headlight for example... take original or photo to an automotive shop.
Good Luck
Apr 07, 2015 | Microwave Ovens
Halogen oven 12lieter lid
Some of the ovens comes with a fuse in the back. Ther should be a cover in the back. This one may have it or not. If so just replace the fuse and you are good to go.
Oct 21, 2014 | Microwave Ovens
Oven light jvm1540dn1ww
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
Regards.
Jan 28, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Hot air function not working
If it's not addressed in your owner's manual, you will need to take the cover off the oven to find and replace it.
The owner's manual will also give you contact information for your manufacturer so you can contact them to find local or nearby parts distributors.
Dec 20, 2011 | Neff B7740N0GB Microwave Oven
The Light needs to be replaced in panasonic microwave NN-S696BA. Where is the light located?
If it is "user replaceable", your owner's manual will cover that.
If for some reason you don't still have yours, you can download it here.
If it's not mentioned in the manual, then you will have to do some disassembly to get to it. (It's not mentioned).
Since that's a counter top model, you'll have to remove the outer cover.
See these help files.
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Then you can take your old bulb to an appliance parts store, big box store like Wal-Mart, or a home improvement store like Lowe's or Home Depot to match it up.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Dec 12, 2011 | Panasonic NN-S696BA Microwave Oven
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
237 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
