Question about Husqvarna Garden
Air filter on my 435 gets pluged up every 10 or 15 min. why?
    New Friend:
It's not likely your air filter would plug every 10-15 min. I suspect you have a bad ignition module/coil. when it heats up running a circuit will open causing it to quit or bog. when it cools down circuit will close and it will run for a while again. It is a common test to use a freezing spray on electrical parts to find a problem.
Posted on Apr 14, 2013
Husqvarna 435 flywheel sticks
look on the side of the cylinder head and see if that model has a compression release thats sticking can you pull it over with the spark plug out
Apr 22, 2012 | Garden
How do I change the fuel filter on a nissan quest 2005 ?
fuel filter is one thing that the intervals dont always need basicaly a fuel filter thats getting pluged will restrict fuel that causes a cutout at full throttle a dirty filter on any kind...fuel air oil water. will filter better as it gets pluged. on a semi u typicaly dont even tough the air or fuel filter untill u see restricion on ur gauge. cars dont have gauges for that. if u havent for a while and think it needs it just change it. there is no true interval for this because its doesnt matter how many miles or hour are on the car. its only how much contaminates are in the fuel. so a better interval for fuel filter would be judged by how many times u fill ur tank. if u frequently put in a little gas then u will get more dust and dirt in there. if u fill ur tank and do it at a depndable station.....fyi the newer the tanks in the ground doesn not meen cleaner. dust gets everywhere and just depends on location. so use your own judgment and replace it when u think u should . if you go on a big trip every year for example u would want to do it before u go. but next year should be ok. then again in a few years. but if u ever have it cut out at full throttle then u know its getting pluged. yes i know full throttle isnt somthing everyone does every day but step it down good and if it goes ur fuel filter is good the only other way would be just put one on every year or 2 and never worie again. hope this helps.
Nov 18, 2010 | 2005 Nissan Quest
HI my zyxel keeps dropping the line.In general its ok then for no reason it wil run 10 mins drop out then start again sometimes it will run a few days, logging into statistics the time counter has started...
MAKE SURE EVERYTHING THAT IS PLUGED INTO THE
PHONE JACKS HAS A DSL FILTER PLUGED INLINE. DO NOT FILTER THE ROUTER...IF THAT DOES NOT HELP THEN CALL YOUR LOCAL PHONE COMPANY TO INSTALL A WHOLE HOUSE FILTER IN THE BOX ON THE SIDE OF THE HOUSE....
Mar 07, 2010 | Computers & Internet
When the engine gets warm it starts to cut out when sawing, take it off the log and give the engine it seems to sound right, Husqvarna 435 16 in chainsaw
1. Clean the air filter.
2. Drain and refill the fuel reservoir with freshly mixed fuel/oil.
It sounds as though the fuel setting isn't quite right. Don't try to adjust it with a dirty air filter (to lean once cleaned) or stale fuel.
If it still acts up I'd take it to a good local chainsaw seller/mechanic. It needs to be warm before adjusting and if they don't make a cut after the adjustment they would never get my saw again. HTH
Lou
Sep 17, 2009 | Husqvarna Garden
Thermostat turns unit one every 5 min
check your filter if it is dirty it will not allow enough air flow and cause the heat limit stat in the unit to trip causing unit to cut off when it resets it will come back on.
Dec 23, 2008 | Honeywell Focus 6300B 5-2 Days...
No heat and filter care light constantly lit
Have you cleaned the filter and the filter compartment?
Try that, then unflug it for about 10 min, then plug it up and try it again.
This will reset some units with an auto reset high temp limit switch.
What happens when a filter gets dirty/clogged is that not enough air is blowing accross the heating device. This lets it get to hot and it will shut off for safety to prevent fires.
If everything is clean and after pluging it back up it still gives you that code you may have a bad sensor.
Dec 06, 2008 | Dryers
Since I've hooked up my internet my phone has gone dead. It is not an outside problem. My phone was fine before I pluged in the dsl. I have disconected the box and tried pluging in just the phone and that...
contact your service provider and ask them to put a filter in your customer service access on your outside phone interface sometimes the dsl will over power the line filters and keep your phone from working try unpluging your dsl and all your phones for 5 min then pluging just 1 phone in and see if you have a dial tone
Sep 12, 2008 | Computers & Internet
Garden Logo
43 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
