Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Too hot in the garage
I have this basic round thermostate in my garage and it works fine but I want to turn it down lower than it will go. I just want to keep the space in the 40s so it doesn't freez but don't want to waste $ heating a space that is rarely used. I have the thermostate turned down to 50 as low as it will go and I also tried turning the unit a little to the right so it's out of level thinking this might fool the reading. There is also another adjustment inside the unit. A thin gold lever with a triangular hole in it. Not sure what this does. Can anyone help? Thanks
  • tano13 Jan 29, 2009
    DMR, Thank you for the link, I'm not sure what kind of a heater it is. The system is oil fired hot water, the unit in the garage is up on the wall. Hot water passes through the pipes inside and a blower comes on when the therm calls for heat. Can I assume it's hot water heat and set it at .08 as per the manual? Also is there anything I can do to fool the system to go off at around 40 deg? Is setting out of level to the left the right direction? Thanks again for your help
    Scholar:
  • 140 Answers
Hello, try this link to download the manual for the thermostat. The metal piece your talking about is the heat anticipator. It's used to calibrate the thermostat to the type of heater that it's connected to. Any more questions just ask. Good luck.
http://safemanuals.com/user-guide-instructions-owner-manual/HONEYWELL/CT87B-_E
Posted on Jan 21, 2009
  • David Robinson Jan 29, 2009
    Yes, if you turn the thermostat to the right you could fool the thermostat into thinking it's warmer, ie. the thermostat thinks it's 50F when it's actually 40F. When you set the temp on an old mechanical mercury style thermostat all you are doing is turning the thermocouple/bimetal coil to advance or ****** it's switch timing. That's why for proper operation you have to use a level to mount it.
    The anticipator is for controlling hysteresis and cool down in the drop out or shut down end of the cycle not to calibrate the starting temp. Make sure it stays set on the correct setting for your type of furnace.
    Other than buying a programable process control device this is a cheap fix.
    Scratch that. I'm an HVAC contractor and I just looked at one of my catalogs and Honeywell makes a thermostat that the low setpoint is 40F. There are several options. How many wires are going to your thermostat and what color are they? Let me know and I'll give you some options.
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Mr heater 75000 btu thermostate turned up exhaust air turns on and ignitor doesnt ignite and times out
Probably your ignitor is bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 23, 2011 | Mr. Heater Natural Gas Garage Heater -...
My pontiac grand am 2003 is running hot. the
Change the thermostate, if that doesn't work it might need a new water pump and new hoses. Try getting the radiator flushed.
Jun 30, 2010 | 2003 Pontiac Grand Am
Fan will not work in "auto" for heat request. fan works fine in "on". digital display on thermostat goes out during heat "auto" request. 24v transformer was weak, so replaced that. now, still same problem,...
What brand of thermsotat do you have, if it's working on auto and not calling on heat then the thermostate is most likey bad the metal plate on the inside may be wore down, you may be able to pry it up to make it work but it you ggive me the thermostate brand I can give you exact details hot to fix.
Oct 08, 2009 | Goodman GMS90703BXA Heater
1999 DODGE STRATUS RUNNING HOT I CHANGED THE THERMOSTATE AND MY FAN IS WORKING PROPERLY.WHEN I NOTICED IT WAS RUNNNING HOT I OPED THE HOOD AND SAW THAT THE LAST TIME I PUT SOME OIL IN THERE I LEFT THE OIL...
Yes if it blew out the oil fill the oil to the full mark then you may have to check your thermostat to see in you turned it upside down or it's not getting water in the lower part of the block. You have to burp the system and get the air out I always put a 1/16 hole in the thermostat to allow for water to flow into the lower block Makes it much faster and keeps you from burning up the engine.
Sep 30, 2009 | 1999 Dodge Stratus
Heater gauge
The sensor is normally found on the lower radiator tank and before getting too quick to buy one, check the connection of it first. Some have a quick disconnect in the body of the sensor, others have a 'pigtail' that has a connector at the end of it.
Simple corrosion can cause loss of contact. If it has two leads, one will be ground so disturb both. If it has one lead, loosen the sensor a little (half turn or so) and re-tighten to clean the grounded side of it.
Typically, loss of the ground is what can cause the temp gauge to peg on the high side.
Feb 13, 2009 | 2004 Dodge Dakota
Powermax boiler 155, when boiler reaches operating temperature the presure relief vale blow's off at 3 bar, when it cools down the presure go's down too, right down to zero needing a water top up before a...
Sounds likes you have a hot water system. Some where you have an expanion tank that is full of water and it should be half full. It will a round tank above the boiler and may even have a site glass on the end off it. It will have a special valve on it to lower the water level in the tank. The tank is to absorb the expanding water as it gets hot, and releases it when it cools down therefore preventing your relief valve from popping off.
Oct 14, 2008 | Heating & Cooling
Heating & Cooling Logo
233 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
