Question about LG HT805 Code Free Home Theater System FOR 110-220 VOLTS
My lg ht805 says disc error - LG HT805 Code Free Home Theater System FOR 110-220 VOLTS
How to remove disc error message for my lg ht303su-a2 dvd cd player because it plays some dvds and other dvds wont play
Check a CD. If it plays, the Optical Pickup for the DVD is worn out and will need to be replaced.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 22, 2014 | LG HT303SU Theater System
I have purchased a lg ht805 dvd system and says disk error when I try to input a dvd
Do this
Go into the setup menu and then into the display setup and highlight the aspect ratio option, then select 16:9 wide (but do not press enter).
now quickly press the following keys in order '1','3','9','7','1','3',9 + enter . Write down all the details that the system information screen provides.
let me know the PROM OPTION CHEERS
Apr 10, 2011 | Televison & Video
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
LG DVB T HDD/DVD 197 won't play dvd's want error
http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
Oct 20, 2009 | Televison & Video
LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Sep 18, 2009 | LG LXD5230 System
My LG LHB977 home theatre Displays NO DISC whenever I insert any disc.What could be the problem???
It may be a dirty "laser lens". It is possible to clean this lens w/rubbing alchohol and a Q-tip.
Disconnect all power b4 disassembly.
Aug 20, 2009 | LG LHB977 Theater System
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Disc error
Recordings are not being finalize. As it starts to finalize it zips through it and then kicks it out as disc error.
Jun 02, 2008 | LG DR787T DVD Recorder
LG V8824w DVD/CD - Disc Error
I bought a lg lst3510A at a yard sale for 20 bux. Lady said that it was new and had never been used. Plugged it in and got disc error when trying to play a dvd. I removed the cover and gently slid the lens pickup to the far back I DO MEAN GENTLY.... IT SEEMS LIKE IT HAD LOST ITS HOME POSITION. This worked for me. IF YOU TRY THIS MAKE SURE THAT YOU UNPLUG THE DVD PLAYER FIRST. Good luck and I hope this works for you.
Mar 16, 2008 | Televison & Video
LG HT805 Code Free Home Theater System FOR 110-220 VOLTS Logo
32 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
