Question about Canon PIXMA MP150 All-In-One InkJet Printer
Getting a flashing "E" followed by a "5" on the digital display.
  • irishjoker35 Jan 21, 2009
    Yeah, I know it can't be the ink cartridges themselves..They're the same ones that came with the printer and have never been used or refilled. I've also tried holding down the Stop/Reset but no luck there either. I've tried running MPTool and reseting the ink levels while in Low-Level Mode and that didn't work either.
  • Anonymous May 06, 2009
    αλλαξα μελανι ..και απο τοτε γραφει ε5 και δεν κανει τιποτα.δοκιμασα μηπωσ δεν το εκανα σωστα αλλα ....το ιδιο
  • 315 Answers
Try replacing the ink cartridges..
I know this can be exspensive but the same solution comes up on a lot of different forums.
Other people have said to hold the stop/reset button down for at least 5 seconds.
Sorry Im clutching at straws but I hope it might help...
Posted on Jan 21, 2009
  • Mike Neath
    Mike Neath Jan 21, 2009
    Also I remember a problem with Epson printer cartridges, I dont know if they some how went out of date but I had some which were about 6 months old and the Epson printer wouldnt even recognise them..
    I brought new cartridges and it all worked fine.
My C7180 display has disappeared. The screen is white with blue lines.
Hey, there might be some problem with display. This problem generally arises in C7180.Following are the steps that you should follow:
1). First unplug the printer from the outlet and wait about 5 minutes and plug it in.
2.) If that doesn't help then you should contact HP about getting it repaired under warranty.
Thanks
Apr 28, 2010 | Office Equipment & Supplies
I have a Savin 9113Z copier that is giving me a error code of 54. Any advice
Hello sir; You do need to reset this error code, procedure as follow;
press 71,hold down "clear/stop"key, until you see the "." in the upper left cornor of the display, then release, after that you press "clear/stop" key again then press lighter key, the 5 will now flash on the display, now enter 97 press start, turn machine off and back on , machine should be running.
Jan 04, 2010 | Savin Office Equipment & Supplies
Canon Pixma MP160 "Head ID Error" when try to print.
E5 is "The ink cartridges is not install or a non supported ink"
Probably one from your cartridges is defective.Replace the cartridges.
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How reset time?
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Regards...
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Baud rate
Please follow the steps given below to reduce the baud rate on your printer.
1. Turn on the HP all-in-one.
2. From the keypad, press * and # keys simultaneously.
3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
4. Press the right-arrow to select System Configuration.
5. Press Enter on the front panel.
6. Press the right-arrow to select R/W Parameter.
7. Press Enter. Parameter 0 will be displayed on the front panel.
8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
11. Press 0, and then press Enter. This will display
12. Press Cancel repeatedly, until the display reads the date and time.
May 21, 2009 | HP Office Equipment & Supplies
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
ما معنىE_5
When the copier displays "E-5" in the copy
counter. Hold down the "·" key, and two digits is displayed in the copy counter. so tell me what are the two other digits for i to can help you because e5 code have about 20 it can be the fusing unit or the main motor or the lift motor for the paper trays
so you should tell me the two other digits for i to can help or if is the fusing unit you can simply enter the service menu and shut down the machine and turn it on again for to enter in the service mode you should press the follow buttons one after other:
1. yellow key [cancel modes ]
2. press 107
3. press and hold the red button [stop] until all light star flashing.
4. then turn off and turn it on again the copier
Apr 23, 2009 | Ricoh FT5832 Copier
Receiving a flashing E followed by a 5 on the digital display.
One of the cartrige must be changed with a new one(or another good cartrige).I had the same problem with the colour cartridge.
Jan 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
94 people viewed this question
old marine
old marine
