Question about Tivo R54040 140-Hours Video Recorder
I want to hook an external hard drive up to my Motorola DCH6416.
What type of hard drive do I need? rpm's, cache, formats, etc...?
My hard disk is not formatting
Go to the manufacture website, www.seagate.com Type: format hard drive.
May 05, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Not able to detect the disk
We're going to need more information to troubleshoot, but if it's a new drive that's never been set up follow the instructions below. If these instructions aren't helpful, then please post back with more info and I'll help you further.
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click "Administrative Tools."
4. Double-click "Computer Management."
5. Select "Disk Management" under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hard drive.
Good luck and thanks for using FixYa.
Apr 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi, I hooked it up on a digital receiver for tv, then I hooked it up on my pc and it looks empty with no files on it anymore...what shoul i do?? Thanks Simone
I'm not sure specifically what you're asking here, but there are a couple of options:
If you just want the Hard Drive to work on your computer again (even if you lose whatever you may have had on it), you'll need to format the drive while it is hooked into your computer.
I don't know which operating system you have (XP, Vista, Windows 7) or even if you're running Windows... so these next instructions may vary:
Open "My Computer" (or "Computer" on Vista/Win7)
Right-Click your Hard Drive
Click "Format"
WARNING! If you format the drive, you will be erasing it completely!
In the format menu, make sure NTFS is checked and do a Quick Format.
When it is done, you should be able to browse the drive, copy files to it, etc...
When you hooked it up to your digital receiver, it may have done its own kind of format so you couldn't load movies onto the Hard Drive and move them to your computer... It's possible that it's a safety feature of your DTV... The only way to know for sure is to try it again after formatting.
Dec 05, 2010 | LaCie 320GB LITTLE DISK USB2 5400RPM 25"...
Hard drive unaccessible
There is a program called On track recovery.
This application successfully recovers data from damaged hard disks.
You will need and extra storage where to transfer the recovered data.
Don;t forget to rate this answer if it helps.
Dec 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Jun 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
How do I get the files to the external hard drive?
First, u have to format your external harddrive, then just Copy and Past your desired forder from your computer to external hard drive.
Oct 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
My harddrive will not save files larger then 4 GB
What is the filesystem format on your external hard drive? there are limits on certain file systems, like maximum size of a single file in fat32 is 4gb. let me know the filesystem on your external hard drive and i will try to consult a few friends for you. regards
Apr 18, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Tivo R54040 140-Hours Video Recorder Logo
619 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Dave
Dave
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
