Question about Jeep Mediacenter / Mygig 430 Rbz Cd/dvd 30gb Hdd Chrysler Dodge
Mygig rbz/rb2 anyone knows how to access the engineering menu on those? i know previous ones are seek+/seek-/menu, is there a similar procedure for mygigs made by mitsubishi electronics?
    New Friend:
Press Radio+Media+Menu
Posted on Feb 23, 2013
We bought a tu-21 engine cylinder leak detector and cant find a instruction manual anywhere does anyone know how to work this detector
This is a 2 gauge unit, and procedures for a very similar one are here
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/
You will need an air compressor or other air pump. Note it is important the cylinder being tested is at TDC
Nov 07, 2013 | Computers & Internet
Does the rbz driver have a manual
Yes, with a new RBZ driver you should recieve a wrench and instruction booklet.
Apr 14, 2013 | Taylormade Rocketballz Rbz Adj Driver
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
How to reset low pressure light after having new tires installed
Though all of these TPMS applications use a similar technology and strategy to detect a low tire, there is no common reset procedure. GM is probably the worst, with 10 different reset procedures depending on the application. Toyota is probably the best, with only one simple reset procedure for all of their indirect TPMS systems (though a slightly different procedure is used on the Lexus models).
TPMS reset procedures may also be found in the vehicle owner’s manual (if it hasn’t been lost). Open the glove box and check the index in the owner’s manual for any TPMS information.
CHEVY IMPALA &
MONTE CARLO
On a Chevy Impala or Monte Carlo with indirect TPMS, a totally different reset procedure is required. You can use the light switch or radio to reset the system. With the light switch procedure, turn the ignition on (engine off), the turn the light switch from OFF to parking lamps three times within five seconds. With the radio technique, turn the ignition on (engine off). With the radio off, hold the DISP button until “SETTINGS” is displayed. Use the SEEK button to scroll down the menu until you see “TIRE MON.” Press the PREV or NEXT buttons until “RESET” is displayed. Then press the DISP button again. You should hear a chime and see “DONE” to indicate the TPMS system has been successfully reset. Use the SEEK button to scroll through the menu until “DONE” is shown, then press DISP once more to exit from the learn mode.
Good luck and this should work for you. They changed the reset procedure on the 2006 Impala.
Dec 08, 2009 | 2003 Chevrolet Impala
RB2 drums not recognied on GH WT
that's because rb2 drums are different than the GH WT ones.
you see, rb2 drums only have 4 colors. (R, Y, B, G) Gh Wt drums have 5 colors (R, Y, B, O, G) plus the Y and O drums are cymbals.
did you buy just the disc or the big box?
Feb 06, 2009 | Nintendo Wii Console
2005 Monte Carlo Change Oil Light Reset
Hiiiiiiiiiiii...........
Are 2 procedure to Reset the oil life.
1-- Using the accelator pedal.
Turn ignition ON with engine OFF
Fully press and release the accelerator pedal 3 times within 5 seconds.
The oil change light will flash a few times and them go OFF.
If the light is still on repeat the procedure.
2-- This procedure need the RADIO, if you have an aftermarket
Radio you don't be able to do.
Turn the ignition switch to ON position,
turn OFF the RADIO,
Press and hold the Tune disp, button for 5 seconds or until
Settings is displayed,
Press the seek ptype or seek pscan up and dow to scroll the main menu,
Scroll until the OIL LIFE appear on display
Press the 1prev or 2next to scroll the sub menu, RESET will be displayed , Press the TUNE disp buttom to reset,
A chime will be heard to verify the new settings and done
Will be displayed for one second.
Press the TUNE DISP to exit from the program,
A chime will be heard to verify the exit.
OK.. I hope this help on your question.
Thank you for use fixya.
Aug 23, 2008 | 2005 Chevrolet Monte Carlo
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
Jeep Mediacenter / Mygig 430 Rbz Cd/dvd 30gb Hdd Chrysler Dodge Logo
890 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
