Question about Grilling
Heating element madel#20070710
I need to find out where to order an element
    Sergeant:
  • 211 Answers
If this is a Masterbuilt, this is the manual... http://www.appliancefactoryparts.com/content/pdfs/139749-1.pdf The part # is 9907090039 Element kit, Masterbuilt 1-800-489-1581. Or do a search on that part # for alternative sources.
Posted on Jan 21, 2013
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Hi this is Erik, my problem is that my dryer wont heat up it works but it doesnt heat up throws cold air
Your/The heating element needs to be replaced. You can repair it yourself...copy serial number and model type down and order element. Sears, Lowes, and Home Depot carry appliance parts for many names. You will have to order it. Relatively simple job...30-60 min job.
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Need the code for a 42 inch LCD TV model ELDTW422 to program our Direct TV remote so it works with the new TV
May I get the madel # of the direct tv remote to help you more. Is it the RC65 or another model
Nov 20, 2010 | Element Electronics Televison & Video
I can't find the heating element in my Frigidaire stackable dryer.
The heating element is BEHIND the dryer drum. You need to remove the drum in order to access it. Keep in mind, if you have a heat related problem, it may or may not be the heating element. It could also be the thermal cut-out (TCO) which is mounted along with the heating element. Again, you will need to remove the drum to get to it. The TCO acts as a fuse and is designed to blow to protect the heating element if it overheats. Check the TCO first to make sure it is not blown. If you need further assistance, please post back with your MODEL NUMBER. I hope this helps you.
Sep 15, 2010 | Dryers
Oven powers up but doesn't heat
When you turn the control to 350 or so the bottom heating element should heat up, if it don't, turn the control to broil if the top element heats up it is most likely the bottom element has burnt out and need replacing. You can find the elements at Home Depot or Lowes, if not in stock at the store, you can order it inside the store.
Feb 13, 2010 | Ovens
The oven will not heat at any temperature setting.
Check wires to heating element. they sometimes break right where they connect to the element. EASY repair, just replace with new HIGH TEMP connector. Or your element has gone bad. Look on element first, for what looks like bubbles, or breakage. Have model and serial # ready when you order or have it repaired, you will need them both. Voltage too.
If oven heats on broil, that is the
Dec 24, 2009 | Whirlpool RF364 Electric Kitchen Range
HEATING ELEMENT IS RURNED OUT
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Jan 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Grilling Logo
528 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
