Question about Ertl Case Magnum 215 Tractor With J and m Gravity Wagons
Error code says bad chip - Ertl Case Magnum 215 Tractor With J and m Gravity Wagons
Computer beeping and won't start up
Dear,
There is a full code list that relates with the problems. You can justify yourself that which type of beeps, you are facing. I am going to write down the codes for you.
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Hope, now it will be quite easy for your do check and troubleshoot the issue.
best of luck, ask further if required.
Mar 08, 2012 | Computers & Internet
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Cannon pixma mp500 code error 6500
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Sorry fro the bad news!
Nov 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My friend owns a joybook R53U with windows xp installed her computer froze and she switched off manually instead of shutting it down properly. now it turns on gets to the safe mode options part then loops...
Hmmmm....
Looping restarts are a pain, mainly because you cannot see the error code associated with them. I am going to assume it is a generic driver error (error code 0x00000007E). That is a generic driver issue. If you cannot start in safe mode, then you likely have a bad memory chip or a hardware device going bad (probably the video chip). Get the diagnostics discs and run some tests on the hardware and memory. IF your hardware passes the diagnostics, then the OS could have a faulty driver. If thats the case, you may need to reinstall. But, before you go that far, try replacing the memory chips.
Nov 07, 2009 | Computers & Internet
I am receiving an error code from a toshiba satellite m35x-s163. The beep code is 1-3-3-1. the machine is unresponsive.
If your notebook has a Phoenix bios then the code you are giving is for Autosize RAM.
The first step is to reseat the RAM chips in the computer.
Locate your user’s manual as it will have detailed instructions and pictures for safely removing and replacing RAM chips.
Without the manual:
1. Unplug the computer.
2. Remove the battery.
3. Then located the door to the compartment that houses the RAM chips -- make sure you are thoroughly grounded with a grounding strap before you touch the chips
4. Remove the screw securing the door, remove the door,
5. Remove the chips, you will probably have to use a small screwdriver to move the RAM locking tabs. Pull the RAM chip or chips out taking care not to touch the contact terminals.
6. Inspect the terminals for any corrosion (if you see any take the machine to a Toshiba service center).
7. If the RAM chip(s) is/are clean carefully reinsert it/them
8. Replace the cover
9. Replace the battery
10. Plug in computer
11. Power on
If you still get the beep codes then either your RAM chips have gon bad or they are the worng chip for your machine or your motherboard has gone bad and you will need to take it to a service center.
May 09, 2009 | Computers & Internet
DMR-EZ25EB; Error code U61 cannot be recovered
take it to a tech to check about the system control chip... the contril chip would have gone bad... and they will replace u with a new chip..
thank u rate me!!
Feb 10, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
No picture, no sound, error code 7
Sounds like one of two problems
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Jan 31, 2009 | Philips 46PP9302 46" Rear Projection...
ASUS M2N68-LA Motherboard beeps
The short then long beep error is indicative of a RAM memory issue. I had the same problem and had to use a process of elimination to determine the bad RAM. Place a RAM stick in slot 1 one at a time. The RAM stick(s) that give the short-long beep error are bad. If all RAM gives you the error it is more likely you have a bad board
Sep 03, 2008 | Computers & Internet
Ertl Case Magnum 215 Tractor With J and m Gravity Wagons Logo
16 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Are you an Ertl Toy Expert? Answer questions, earn points and help others
