Question about Kyocera Office Equipment & Supplies
Black lines appear when printing on kyocera km2550
All prints appear with the same 4 lines running across the page lengthwise as the sheet is ejected from the printer.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Check first cleaning blade then clean, then coating in drum charging primary check screen grid, or the upper and lower if there is lines it may reflect in copy
Posted on Feb 13, 2016
  • Kyocera Expert
  • 337 Answers
Could be fuser tracking where the pawls ride on the heat roller, could be abrasions on drum, could be main charge corona, could be LSU glass. Can you provide a sample print?
Posted on Jan 30, 2013
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
  • 134 Answers
SOURCE: BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Posted on Jun 30, 2008
  • 990 Answers
SOURCE: Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Posted on Jun 01, 2009
  • 120 Answers
SOURCE: Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
Posted on Jul 09, 2009
SOURCE: Printer is printing black lines across all print jobs
i would check the fixing section of the machine which is the hottest part of the machine. weather it is a film or roller you probley have a mark that unit
Posted on Dec 04, 2009
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Jan 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
Black lines print on black and white printing
Sounds as if the drum needs to be replaced if it does this on copies and prints.
If it just happens on copy when using the document feeder then try cleaning the narrow piece of glass that is located just to the left of the large piece of glass.
Jan 09, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
I have canon mp145 printer. when it starts to print it gives the service error 5100 message
Tried greasing (actually WD40) per linzi's reply, but it did not help. In the process, I think the solution presented itself. There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 27, 2011 | Canon MX700 Office All-In-One InkJet...
How to solve the error 5b00 for mx700?
Oct 05, 2010 | Canon MX700 Office All-In-One InkJet...
Error code 5100 on mx700 printer
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This part is related to the optical encoder which tells the print head where it is. Look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start up sequence. Softly clean this strip with a damp lint free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 28, 2010 | Office Equipment & Supplies
I have a canon MX700 and it is showing error code 5100, I looked it up in the manual and there is nothing for this code..help!
Try this.....
Sep 09, 2009 | Canon PIXMA iP90 Mobile Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
129 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
