Question about Briggs & Stratton Garden
No spark briggs stratton 11.5 - Briggs & Stratton Garden
  • 169 Answers
Http://www.youtube.com/user/backwoodsctryboy?feature=mhee
check out my youtube channel and search for ignition testing
Posted on Jan 16, 2013
  • 86 Answers
SOURCE: gas comes out of spark plug hole
You have a Float problem you also make have gas in oil.
Posted on May 12, 2009
  • 201 Answers
SOURCE: I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Posted on Jun 07, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: 1979 briggs and stratton 11 hp how to fix
If it is, as you say, a 1979 or so engine, the crankcase breather could have well worn out. This will cause the oil burning and blowby. Replace the breather as an assembly, they are cheap and available from any Briggs dealer. The leaks are probably loose bolts and/or bad gaskets. You will just have to figure where the leaks are and replace the appropriate gasket. The breather could also cause the leaks so do the breather first then run it for a while to see if it is still leaking
Posted on Sep 22, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Why don't I get spark on my briggs and stratton 3.75 model 98902
Did you check the ignition shutoff wire? Make sure it isn't grounding. It is a common Briggs problem. Take the wire off of the switch contact and check for spark again.
Aug 19, 2014 | Garden
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Toro 1987 11-32 I/C Professional rear mounted 11 hp Briggs and Stratton need wiring diagram so can resolve no spark at plug with new armature/module and spark plug. Thank you!
i don't have the manual but unplug the harness to the engine and see if you get spark if so check the safety switch on the clutch/brake pedal
Jun 09, 2012 | Garden
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
79 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
