Question about HP ProBook 4310s Notebook
Error verifyng Embedded Security pasword. Press Enter to continue.
    Sergeant:
  • HP Expert
  • 427 Answers
Check the BIOS for embedded security password. Disable it
Posted on Apr 17, 2013
Hi! I need to fix a friend's computer, and the problem is that lot of errors appear when I am turning it on, and to be able to run the windows I need to press F1 tot go to Bios, than exit and save...
Simple tips to fix this issue:
  • Clean the Temporary Stuff and Browser Cache
  • Remove Obsolete Registry Entries
  • Disable Startup Programs & Services
  • Customize Windows for Best Performance
  • Uninstall Programs and Disable Windows Features
For Instant Fix use Reginout system utility.
Jan 17, 2013 | Computers & Internet
Svga vlp - es5 projector control key locked problem
Hello
Your projector is in security lock Enabled condition. If you have forgot the pascode . You can change the password by
Use the Menu'UP'/'Down' '<'/'>' buttons to enter the four digit pascode. The default password is "ENTER,ENTER,ENTER, ENTER". After this is entered, you can put in a new pasword. Therefore when you use this function for the first time, pleas input "ENTER" four times.
To cancel the security lock, press the Menu key, then turn OFF the "Security Lock" setting on the INSTALL SETTING menu.
If you call the customer service center because you have forgotten the password, you will need to be able to veryfy the projectors' serial number and your identity. The process may differ in other countries/regions. Once your identity has been confirmed, they will provide you a password. OK.
Oct 22, 2011 | Office Equipment & Supplies
Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
Jan 28, 2010 | Acer P3250 DLP Projector
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
Error Message at Startup
Ok at boot up press F1 to enter bios, when loaded select the following sequence of headings
1. Security
2. Security Chip
3. Clear Security Chip
That should solve the problem
Apr 16, 2009 | Computers & Internet
CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
Oct 12, 2008 | IBM NetVista PC Desktop
CMOS erroe 0193
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
I have a psp 1000. i want to connect to the internet. so i go to settings then network settings. i click on that then go to infrastructure mode.i select new connection then scan. then i select humberto...
Ok I ahve had this problem too.You can't just choose easy,you have to actually choose what type of security your router has or you can't connect to it.Be sure to enter your router information.
Sep 21, 2008 | Video Game Consoles & Games
HP ProBook 4310s Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
