Question about HP LaserJet 3550 Printer
Set black and white print option on hp 3505 color printer
SOURCE: Hp K80 printer
I had the same problem, and it seems to have corrected itself. I too, installed a new "45" black cartridge and got the message to remove and check color cartridge. After I removed it and cleaned it the message stayed on the display for about 5 minutes and then asked me to "align cartriges." After I aligned them I had no problems.
Posted on Jan 25, 2008
dotball
  • 64 Answers
SOURCE: HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 05, 2009
SOURCE: Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Posted on Oct 23, 2009
  • 217 Answers
SOURCE: Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Posted on Apr 29, 2010
aimrans78
  • 52 Answers
SOURCE: My HP Photosmart D7160 is printing color pictures
try to reinstall the drivers
everything is going well with the hardware
only software has some bugs
Posted on Jun 18, 2010
My HP 1315 still prints black and white just fine; however, it no longer prints in color. I have replaced the color cartridge, removed the celophane from the cartridge, cleaned the printer, and alligned...
Open printer properties.
Start --> Printers and Faxes --> (Right-click your printer and select properties)
Check whether you have selected 'Black & White' option for Color property in 'Printing Preferences' (in General tab) and 'Printing Defaults...' (in Advanced tab).
Set it to Color option.
Best of luck!
Aug 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
My hp 3505dn printer prints a full page coat of black over the print job
Black toner cartridge failure, replace it for another (Q6470A) and try print.
Jul 22, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
How do I set my 5550n printer to print only black and white copies and color on demand?
If you go into control panel then go printer options you should see your printer icon. Right click on it and go printer preferences or printer properties and I think there is a colour tab where you can set it to just back and white
Sep 22, 2009 | HP LaserJet 5550n Printer
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Is there a setting to print in B/W only?
Yes
When printing press file,then print, from there select printing preferences go over the pages and look for black and white setting or grayscale setting.
it will print in black and white only.
May 29, 2009 | Office Equipment & Supplies
Can't print in color
Hi there!
Problem with your print settings.
Go to Control Panel > Printers and FAxes > Right Click on your printer and click Printing Preferences
Depending on your model, the preference page would show a drop down control or simply an option that says something like :
Print in : Black & White /Grayscale
or most models would say:
COLOR: [ ]BLACK [ x] COLOR
Now, set it to colored.
Hope this gives you an idea!
-levibit-
Mar 18, 2009 | HP PSC 1610 All-In-One InkJet Printer
Only prints in black and white
before you print go to the print properties or preferences, in there see if you find a setting that says black/white or color. select color then print.
you may or may not have this option. the older HP ink-jets defaulted to Black/white and you had to manualy select color from the current document you where printing.
Dec 05, 2007 | HP OfficeJet 6110xi All-In-One Thermal...
HP LaserJet 3550 Printer Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
