Question about Bose Cinemate Series 2 Ii Interface Module Only Receiver W/o Remote
No green light or red mark
And No light comes not heard
61"dlp, a few seconds after turning on I heard pop from the back & the tv turned off. I have 2 short horizontal green lights & 1 long horizontal red light flashing on front of tv. What does this mean?
Power supply board is the first one to test. See if you can spot burn marks or components on the other boards. The bulb could have exploded too.
Apr 16, 2017 | Televison & Video
On my '87 chevy s-10 there is a green wire coming from the ignition, a red wire coming from somewhere else, and two posts on the solenoid one marked "s" and the other marked "r"...
the one marked s is your switch wire r is regulater which you dont have to worry about check the wires with a test light when you turn your ignition to start the one that lights is your switch wire
Sep 08, 2011 | 1987 Chevrolet S-10 Pickup
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
Thanks.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
The light comes on a poping sound occurs the light goes back off. The set never comes on. the light come on again and and immediatly shuts off
Sounds like a Arcing CRT tube(s)!, You may have a bad color tube!, Set has one red,blue & green tube. If ones at fault, And you heard a POP - more then likely a BAD CRT, The Set is Turning Itself OFF to prevent any more Damage!.... onegeo
Jul 07, 2009 | Televison & Video
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Bose Cinemate Series 2 Ii Interface Module Only Receiver W/o Remote Logo
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
