Reddy kerosene heater will not stay lite.
Performance
  • PRESSURE9 Feb 02, 2009
    MY HEATER WILL RUN FOR 20MINS THEN GO TO FLAME FAILURE CHANGED GAS FILTER BOTH AIR FILTERS ADJUSTED PUMP PRESSURE AND CHANGED FUEL STILL HAVE THE PROBLEM
  • Anonymous Feb 17, 2009
    im working on mine now. It appears that the fan is blowing too hard. Im trying to find a way to slow the fan down a bit.
The problem still exist, but do not care to pay 9.95 for this service.
Posted on Jan 22, 2009
Runs 6 seconds cuts off never lites
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Jan 15, 2010 | Reddy HEATER RH125T 125,000-BTU...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have reddy heater125t the flame lite
It sounds more like airflow and too high of a temp. The fan blades and return vent side must be very clean to keep this big guy pushing the btus out of the heater. A restriction of any kind could cause this overheating situation causing it the shut itself down. If you are confident that air is not the problem, make sure the nozzle that the kerosene comes out of is clean also.
Jan 09, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dead Reddy heater 170T
When chaning the filters, did you clean out the flame chamber, a lot of carbon and suot will build up inside and cause the unit not lite.
Feb 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
