My tv had lines going through out the screen wondering on the setting for my Sony wega 52"
  • Televison & ... Master
  • 16,043 Answers
First thing to do is check the menu screen to see if it has rolling images. If it does not then it is not likely to be the television. Check all the inputs from antenna, dvd, cable etc.
Posted on Jan 10, 2013
techman
  • 3130 Answers
SOURCE: Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Posted on Aug 09, 2006
  • 304 Answers
SOURCE: LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Posted on Jul 16, 2009
  • 188 Answers
SOURCE: 42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Posted on Nov 02, 2009
UpGrade
  • 113 Answers
SOURCE: my sony wega 3lcd tv seems to have long dust lines
Dust lines? Please explain. Are they single pixle lines on the screen itself? These are the signs of a failing display.
Posted on May 25, 2010
AJIN G
  • 6694 Answers
SOURCE: horizontal,wavy lines on sony xbr4 52" sony lcd tv
hi,
check the ground connection of your house wiring. fist of all remove all the external input like set top box, cable connection, dvd etc from the tv. Then power on the tv and watch is the wave is there or not. if it there then ,if the tv power cord comes with three pin connector then remove the earth connection on the wall outlet socket to which you connect its power. the connect the power and switch one the tv.
if the wave will not appear then connect external devices (set top box, dvd etc) one by one and watch which device produce this wave in the tv. also check the ground connection of that device which produce this wave.
If all these will not help full then the SMPS power supply of your tv have some problem. Normally this type of complaint arises due to the faulty Main filter capacitor. you can see it in the power supply.. It will be the big capacitor according to others. Normally There will two or more. replace the same. will solve this problem. if you need any more assistance feel free to contact me through fixya
ok
Posted on Mar 05, 2011
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Picture problem
This is not a solution but a correction . I stated that there was vertical lines but that should be horizontal Lines. I am having a tech come tomorrow to look at it as it is still under waranty.
Thanks
Jan 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony wega
If this is a rear projection lcd tv then yes it is the lamp, yes it is easy. no need to reset. and yes this is common, lights last around 2000 hours
Jun 21, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
