Question about Sharp Rare El-5100s Scientific Calculator & Case
Sharp EL-5100S LCD display is getting dark around edges
Is LCD replaceable or repairable?
2 Suggested Answers
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
Have replaced sound board and t-con board on Un60 Have replaced sound board and t-con board on 60" led and still have dark picture. Don't know what else would fix it ?
You have a led that has lost continuity. On edge lit TV's LED's are run in series on a module. One bad LED is all it takes to make the entire module fail.
The LCD display panel will need to be removed from the frame while the led module is repaired or replaced.
With a screen this size two people would be needed to remove the glass from the frame. This would be coordinated effort using extreme caution in handling the ribbons around the outer edges of the glass. Some manufacturers have used superglue on one or more edges, if found don't try to remove it without using superglue solvent to loosen the bond. Good Luck.
Mar 03, 2016 | Samsung Televison & Video
How to darken sharp el-520w contrast?
If it can be done, you need to press SETUP then choose CTRST and use your left and right arrow keys to adjust the darkness of the digits on the screen. Unfortunately, some of the older models do not have this ability so if you do not find that that menu option it means that you cannot do it on the calculator.
Jun 25, 2014 | Sharp EL-520WBBK Dual-Powered 12 Digit...
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do i get the back off of my 2232 monitor? It is dead.... no pic at all ... maybe bulb gone?
    The case is most likely snapped together. Check around the perimeter for any screws first, then use an old credit card to run around the edge to separate the plastic. Just go slowly and pry around the edge until you get the tabs to pop.
    Once inside the back of the lcd, you should have two circuit boards. One will be for power and the other for feeding video to the lcd. If you have no video signal at all, then the problem will reside on the video board. However, if you have an image but the screen is dark, it may just be the bulb.
    DIY bulb replacement is possible if you are familiar with electronics and soldering. Having it repaired professionally is usually close if not more than a new lcd.
    Mar 24, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
    Left side of screen is dark
    When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
    If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
    If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
    In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
    Feb 14, 2011 | Philips Televison & Video
    Screen getting dark on sharp pc-m4000
    You most likely have a defective screen - a defective inverter or a CCFL lamp. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
    Jun 03, 2009 | Sharp WideNote M4000
    Blackening around edges of Philips 55PL 55" LCD
    Check any magnet or some speaker are near ur tv . Off it for 1 hrs , re on it & check
    Dec 23, 2017 | Philips 55PL9523 55 in. LCD Television
    Display not showing correctly
    Did this machine get wet? Or was it dropped? It sounds like the lcd display is either damaged or defective! John
    Jun 12, 2007 | Sharp EL-334AB Calculator
    Sharp Rare El-5100s Scientific Calculator & Case Logo
    83 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
