Question about Pioneer DEH-1000 CD Changer
The light for the faceplate is not lighting up. The light is either very dim or its not working and i have to tilt the radio and look at it at a certain angle in order to see whats on the screen
Radio lights are out
what lights, the dial back lights, is it stock>?
the radios have 3 power sources
1 for radio and amp.
2: dial lamps (dim,) if the other cars dim-able park lamps work then
the radio lamps are bad, or not connected (1 wire)
3: memory. power.
my guess is the rad back lamps are dead.
so turn on the parking lights (Head ligths 1st click)
does dashlight up.? no, turn the dimmmer up.
do they light now? yes, and radio no?
if no radio lamp now, the lamp is bad or wired wrong or the fuse blew
that the dial feed wires to.
if not stock, any thing is possible, (infinity)
Dec 01, 2013 | 2007 Honda Accord Sedan
Brakes short lights
You need to get you alternator tested, it sounds like the current output is too low.
Mar 11, 2012 | 2005 GMC Safari
When i turn headlights on...radio lights go out..they come on when i turn dimmer switch..but then dome lights wont go off...tried it on all different positions...2008 patriot
It sounds to me like you may have a defective dimming switch. Are the instrument cluster lights working as they should? Do they dim/brighten with the dimmer? If the instrument cluster is working OK, then it could be an internal problem in the radio unit itself. Your panel lights are computer controlled. The processor in the instrument panel controls them. It uses a digital signal to "tell" the radio to either dim or brighten its lights. If the radio is failing to do so, the radio is the most likely cause since the lights work on "full power" which is also commanded through the same data lines. (this eliminates the signal from the cluster and the connection through the data lines.)
May 23, 2011 | 2008 Jeep Patriot
My KD-LH810 turns on and plays the cd that is in it but the faceplate does not come on and it continues to play the cd - I cant turn it on or off and none of the other buttons work on the faceplate work so...
wipe the connection where the face connects at i had the same problem and it works fine after cleaning the connection and i will guess the power light itself is still lights up and no other button lights or the screen itself if that is correct then u most likely just have moisture in the connections try wiping it with a dry soft cloth
Oct 27, 2010 | JVC KD-LH810 CD Player
The sunroof is tilted open and won't close. When
Sounds like sunroof is stuck, motor can't overcome load. Cheap test: car off, interior light turned on try to move sunroof, does light dim? If yes motor is trying to move but can't. If light does not dim then motor not getting power.
Mar 09, 2010 | 2002 Pontiac Grand Prix
No back light on display
I know that most Clarions have an "illumination" wire usually orange and or orange/white. If the unit only has one, then most likely it is for a "dimmer circuit" and not atraight illumination. Let me know. If by putting power on tat orange wire does not do it, then you have a bad "bulb" in the faceplate.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Clarion DRB2475
Light out on toyota Sienna radio
FIXED MINE! My 2000 Sienna XLE had the same problem with the lights not working. They would flicker on once in a while. I took off the face plate, cleaned the radio with a "can of air" to remove any dust, put electrical grease on the face plate contacts and the plugs on the back of the radio. Reassembled and the lights worked better, but dim and flickered off a bit. Knocked on it a few times on the side to get those contacts to work better and it is now working. My guess is the contacts on the faceplate were not making good contact. If I had to do it again, I would pull on and off the face plate a few times after installing the electrical grease to help loosen up any corrosion for a better connection. That would probably eliminate the need to beat on the side of the radio after reassembling. This fixed mine. Hope it works for you.
Dec 08, 2008 | 2000 Toyota 4Runner
Kenwood KDC-519 Faceplate Problem
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Feb 23, 2008 | Kenwood KDC-519 CD Player
No response from the KDC-519
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Sep 04, 2007 | Kenwood KDC-519 CD Player
Pioneer DEH-1000 CD Changer Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
