Question about Microsoft Xbox 360 Controller
Left joystick how exactly do i get the first one off?? and were can i find a replacment
  • 744 Answers
Hi.. new josysticks are available in leading game shops and in gaming accessories shops. u can purchase over there. if its a new one u can ask ur dealer to replace with a new one.
Posted on Jan 21, 2009
My Xbox one controller left joystick is always moving to the right.
sounds like the microswitch is stuck. The return spring won't help resolving this. more than likely replacing the controller will be your most efficient means to resolve the issue.
Oct 31, 2014 | Microsoft Xbox Video Game Consoles & Games
Tip
Resetting the Lamp Timer
After replacing the lamp, you need to reset the lamp use timer. The manual is a bit cryptic on how this is done. The manual says "Fn. Up > Fn. Dn. > Vol. Dn > Vol. Up > Enter > Power" However, my remote has no "Fn" or "Vol." controls. Further study of the manual shows that "Fn. Up" = joystick up; "Fn. Dn" = joystick down; "Vol. Dn" = joystick left; "Vol. Up" = joystick right; "Enter" and "Power" are keys on the Remote, "Enter being "6 o'clock" position on the ring encircling the "joystick" I am calling the control that one would use to move the cursor on the screen the "joystick" Thus to reset the timer, key in from the remote "cursor up" "cursor down" "cursor left" "cursor right" "enter" "power"
on Sep 12, 2008 | LG RD-JT30 Multimedia Projector
Nutron r51
The age of the Nutron is not the issue, unfortunately. I have seen problems with this model right out of the box. The joystick control is the first area to check. If you have to compensate the joystick so far to the right to correct, you may have a damaged joystick gimbal. You may also have a bad joystick control board or damaged connecting cable to the controller on the bottom frame. Check for damaged, pinched loose or disconnected wiring below at the controller module. With a folding frame it is easy for the wiring to be become damaged or dislodged. Check for cut damaged pinched wiring at the joystick. With a handheld programmer (dealer) you can check for error codes in the fault log. With a poor performance issue there may not be a fault recorded in the log of the computer module. I have also seen these motors fail prematurely. In this case your left motor is dragging or weak causing the chair to go left. With a programmer (dealer tool) you can compensate for this while waiting for new parts(temp fix). Sometimes the motor brushes burn or hang up. Try blocking up the chair off the ground and run it no load to check for motor performance and unusual sounds. Check for joystick dead spots or uneven action. A quick check of the joystick would be to plug in a known good one at the dealer to test. With the chair blocked up try tapping the motor housing to see if the performance changes. Inspect the brushes if you have access to the brush caps.Check the obvious first, plugs, pinched, broken wires and partial plug disconnects and corrosion. If you have a voltmeter you can do some checks on the motors and brakes. Going from memory, the motor leads large black and large red should read zero ohms with the 2 small white wires for the brake reading between 60 and 70 ohms. Check the Invacare manufacturer website for exact specs and technical info for this model.
Hope this helps.
Mar 22, 2014 | Invacare Supply Group Nutron R51 LXP...
Don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
My shoprider creeps backwards on its own
Problem is your joystick is broken, I had the exact problem.
The plastic parts inside your tiny joystick is cracked due to abuse, likely someone pushed on it too hard, or banged it against something.. All it takes, is 50N, or 5 kilograms of force, to break it. It is a very delicate multi-axis inductive joystick made by Penny and Giles,
My advice is to replace the Joystick, which costs $200-300
A lot cheaper than replace the whole controller, which could cost $1000 or more.
Jun Lu
Oct 05, 2009 | Electric Mobility Shoprider Electric Power...
Left joystick sticks
Sounds like the joystick is sticking, the only thing you can do would be to take apart the joystick and with a slightly damp washcloth, and clean off the joystick. Then after you clean all the stickiness off, put the joystick back together and the screws back on and it should react like normal.
Courtesy of Ehow here is the link that gives instructions on how to take apart the controller:
http://www.ehow.com/how_4865722_apart-xbox-controller.html
Aug 07, 2009 | Microsoft Xbox 360 Controller
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Cant go left with the joystick more in msg
remove joy stick rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing the left one .otherwise u can replace the joystick from nokia care centre.
Oct 09, 2007 | Nokia 6600
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
Microsoft Xbox 360 Controller Logo
64 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
