Question about Sony 42 inch KLV-42EX410 Multi System LED TV
Sony KLV 42EX410 LCD TV works but no picture.sound is ok.
SET WORKS but no picture.sound is ok.supply voltages are correct.screen comes.
  • Sony Master
  • 8,617 Answers
LED driver is the most common cause. You should be able to get replacement parts from www.tvcircuitboards.com they can assist with troubleshooting why the LEDs are not lighting
Posted on Jan 09, 2013
SOURCE: SONY KLV-40U100M LCD TV will not power up. looking
by going to people that are true helpers and not looking for the almighty dollar...............
Posted on Oct 27, 2009
Testimonial: "I believe !!!!!!!!!!!!!1"
  • 231 Answers
SOURCE: sony tv model klv-32u100m dead standby 5 volts ok
most probably is (a) board ..very common on these models.These boards are made by RoHM.These are similar and used in maganvox,philips and others..Very common breakdown
Posted on Nov 30, 2007
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
SOURCE: REPLACEMENT LCD PANEL
Have a look here I have the same problem and have been looking for 3 days...I hope this helps as I have tried the service manual and the part number is...1-805-870-21...with no luck...http://www.invertercentral.com/qrySpecSheet.asp?page=srlp&name=LTA320W2-L02&number=LTA320W2-L02&title=Toshiba&Country=Australia
Posted on Jun 16, 2008
SOURCE: Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Posted on Jan 31, 2009
I have sony lcd tv,klv 32s310a,,, power on sound coming,,but no display light,after few seconds,power off,, is this power supply problam,,,250uf 450v..capacitor problam,,or other reson of this problam
The chances of the large cap in the hot side of the power board being bad are almost non existent, that part very seldom fails. test your PSON voltage after the set has shut off and see if you have about 3 volts there, if you do then the main board is working ok and its in the power board, next thing to test is if the power factor correction is working, if its not working correct then look at components in the hot side of the power board, if you see PFC working ok where the voltage of the large filter cap rises to just under 400VDC when the set powers on then look at issues with the cold side of the power board, remember when testing the hot side you can not use chassis ground, the low side of the bridge rectifier must be used as the ground ...good luck!!...other option if you determine you have power board issues is to replace the board verses service it yourself, some power boards can be kind of spendy though where they can usually be fixed for a few dollars.
Jan 03, 2018 | Sony Televison & Video
Sony klv-42ex410 blink 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 09, 2014 | Sony 42 inch KLV-42EX410 Multi System LED...
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Hi, i have replaced the faulty power supply but now the leds don't do anything anymore. The screen is active but stays black. The backlights are on. When i plug the tv into the mains i also can hear...
If the T-CON board is dead,you will see black screen (no picture) but you will see slight glow due the backlights is still on. Check the fuse and voltage on the T-CON board, dead main board will not be sending the voltage to the T-CON board.
But you are saying taht you cannot get any button on the TV to work, that will point the problem to be in the main board.
You will need service manual to really go in-depth troubleshooting.
You can download here for free: http://elektrotanya.com/?q=showresult&megnev=sony&megnev2=KLV-27HR3&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Aug 26, 2011 | Sony KLV-27HR3 27 in. LCD Television
Sony klv32t550a lct tv probllem: tv sound ok but no display and video
dear User,
supply board isshue.kindly take off your rom lite then check if dim picture is coming then its supply issue
Feb 10, 2011 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
Sony KLV-40U100M Screen replacement
If this were just about any other brand, you'd likely be able to find another brand of TV with the same size screen and swap the inverter boards and the LVDS board. The problem with Sony is that the company uses internal designations. If you have homeowner's or renter's insurance, it might cover some of the cost. Otherwise, put the damaged set on eBay (you'll get a couple hundred dollars plus shipping) and go buy a new set. Likely, any larger set for sale with a good screen is going to go for more on eBay and finding one is rare.
Jan 31, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
OK SOUND NO PICTURE
More information is required. What do you have hooked up to the TV and how is it connected? Do you have a menu/OSD (on screen display)?
Jun 25, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony 42 inch KLV-42EX410 Multi System LED TV Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
