Question about Denon AVR 1312
Denon avr 1312 green power flashing green 7 times
No display and flashes 7 times green then solid
    Genius:
  • Denon Master
  • 1,054 Answers
Sounds like a bad power transformer. Would need to go in for repairs.
Posted on Jan 09, 2013
  • 12 more comments
  • densphone71
    densphone71 Jan 09, 2013
    both transformers tested ok ,was hoping fr specific code ie # of flashes to narrow down which portion of amp. board was bad before tear down. thank you though Steve.:)
  • Steve K Jan 10, 2013
    Does the display ever light up? Or is just the power button flashing?
  • densphone71
    densphone71 Jan 10, 2013
    Its stuck in protect mode,so it wont light up until service is performed.Did the micro processor reset and get a slower steady flash .talked to electronic express tech.(autherized for denon)suggested that when flashing its the micro p. doing diagnostic and display will remain of until repair on amp. board is done.But would not tell me codes so I guess Ill trouble shoot the board 1 channel at a time.
    There are no flash codes for denon (I am an authorized servicer as well). If the display does not light up when you do the reset, it is something other than the amp. When doing the reset, all segments of the display should light up. If they don't, it still sounds like a open main power transformer.
  • densphone71
    Thats good to here Steve.Much easier repair do you think maybe the small trans.?
    Large main power transformer is where I would look. Disconnect the two wire input cable going to it and check continuity for the two wires. they should be a short - if not, the transformer is bad.
  • densphone71
    densphone71 Jan 11, 2013
    you hit it on the head Steve..thx..looks to be a thermal fuse on primary side.Could probably eliminate and jumper since there's a slow blow on board next to power in right?
  • Steve K Jan 11, 2013
    Nope, thermal fuse is buried inside the transformer core. No way to get around it without replacing transformer
  • densphone71
    Any idea's on were other than canada to get a transformer? And I'd like to know why Steve K. is not on the" top" of the expert list.
  • Man Bdr Tamang
    Man Bdr Tamang Apr 16, 2014
    Any idea why I have to put off and on several times before the system really gets ON
  • Steve K Apr 16, 2014
    can you give me more info on your question Tamang? What kind of unit are we talking about and what is the problem with it
  • Eric Sustaita
    Eric Sustaita Feb 05, 2015
    Hi Steve K, Do you know where I can get parts for a Denon AVR 1312? Trasnformer...I think that is bad and the Thermal fuse...
  • Steve K Feb 06, 2015
    Eric, you can get one at partsearch.com the p/n is 943101009640D for a USA model
  • Eric Sustaita
    Eric Sustaita Feb 06, 2015
    Thanks so much Denon Master Steve! You are the MAN! (Now I wish it was not $120 - wowsers)
3 Suggested Answers
SOURCE: Denon AVR 1804 Switch on and
try to reset it
To re-set the 2802, just do as follows:
1. Switch off at unit's main power switch.
2. Hold A & B buttons and turn power back on.
3. Check entire display is flashing at approx. 1 second intervals, release the 2 buttons, microprocessor is now initialized.
Hope this helps.
Posted on Sep 03, 2008
Gurudristi
  • 98 Answers
SOURCE: denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Posted on Mar 06, 2009
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Can I get audio out on a denon avr-1312
what are you wanting to audio out to? the AVR is the audio component of a setup so am unsure as to why you would want to
Feb 27, 2014 | Denon AVR 1312
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
No - i560 used ink tank is full (so say the warning display) I need to fix this as our IT department will not. I need to know how to fix the problem
To get round the ink tank (sponge) full problem
you can try following
first turn sponge over then
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 01, 2011 | Office Equipment & Supplies
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
Denon AVR 1312 Logo
371 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
