Question about Kenmore 92812 / 92814 Electric Kitchen Range
On my Kenmore Range the oven will not turn on. The indicator light will not light. It has something to do with the timer buttons not being set properly
I am having the same problem
Posted on Feb 06, 2009
Problem solved. Thanx
Posted on Jan 22, 2009
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
Electric went out and when it came back on everything works except oven and digital timing. Needs reset.
The digital timer needs to be set to the manual mode for the oven to work. If the timer is lit then play with it until it goes back to manual. Turn the oven on and keep an eye on the indicator light. When it lights the timer is on manual. If the timer is out and not working you may need to get a new digital timer. This is a problem which occurs from time to time.
Feb 13, 2011 | Whirlpool Accubake RF362LXTT Electric...
The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
hello,
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thanks for using fixya
Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Frigidaire duel fuel range model # 52 393H3 3S CPDS389CC1 Ser NF24920776 the range tripped the breaker while baking,after resetting the clock flashes and PF is displayed and no buttons on panel work.The...
I have the same problem with an identical oven. In fact my serial number indicated my oven rolled of the production line six ovens before yours.
Please let me know how you fixed the problem.
Thank you.
Kaid
Mar 16, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Oct 04, 2007 | Kitchen Ranges
Kenmore 92812 / 92814 Electric Kitchen Range Logo
130 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
