Installing a Miele WS5425 Washing Machine with cold water fill only?
Hi have just inherited a WS5425 which i want to install in the garage - in the user manual which i found on the net it says that although it it set up with hot and cold fill hoses it can be changed to cold only but a service engineer needs to reprogram the machine - does anyone know if this is a simple procedure and how to do it ? and also would both hoses need to be used for cold fill ? thanks in advance for any advice Chihuahua
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
SOURCE: Bosch Classixx 1000 Express washing machine won't fill with water
my washing machine bosch clasixx all in one does not rinse clothe properly. there is a residue of washing powder. Where is an extra rinse button
Posted on Jun 18, 2010
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Posted on Jul 21, 2010
SOURCE: Miele W770 washing machine won't cycle through
Hi Sandy,
I had the same problem and some time later it stopped completely. The probmlem is in the Prorammer.
UNfortunately it is very hard to find because the appliance is very old. If you find one, I can tell you in detail what is the sequence to change it.
Posted on May 22, 2011
Testimonial: "Thank you! We figured it was one those electronic parts. What we can't decide it whether it's worth it to call someone in to fix it. "
  • 72 Answers
SOURCE: My fisher and paykel smartdrive 058 which has a
i am pretty sure its the main board, the easiest way to solve the problem is replace a the main board with a secondhand board, as well as obtaining a bag of spare parts, out a good working machine with faulty seals. You may have faulty seals if the machine is dormant for 3 years. I advise people never use washing powder in their washing machines, just use liquid detergent like Cold Power. the washing powder cakes up in the machine and when harden can be very abrasive and destroy the seals.
Posted on Dec 07, 2011
Have a Miele 1612 washer whose heater element comes on during any cold only program. As we are off-grid, any unnescesary power useage is unacceptable. Is there something I can reset, or do I just remo
Hi Ed ..
The following is from the Miele handbook and would indicate that the machine can have the water temperature adjusted...... However I suggest that by merely disconnecting/removing the element
the machine's temperature sensors would not allow the machine to work..
A compromise may be to select the lowest wash temperature (ie 30c) This is better than cold water for detergent economy and effectiveness, and machine life.. I understand your situation.
Good luck
Nomess
http://m.miele.ca/OperatingInstructions/en-CA/Laundry/Washing%20machines/Previous%20models/Miele%20Washing%20machine%20Manual%20W1612.pdf
Page 50
Tap water line (cold water) The tap water connection is established using the inlet hose with the blue marking. If the washer is connected to this line only, the appliance will need to be reprogrammed to cold water fill only. Please contact your Miele dealer or Miele Customer Service for reprogramming instructions.
Feb 05, 2015 | Miele Washing Machines
Installing a Miele WS5425 cold water fill only?
if you only want cold water for washing, just select cold wash in the program settings and turn off the hot water tap
so the settings you will be looking at are --like --
tub fill ---low water medium water or high water
water temp cold or hot
rinse hot or cold , wash setting --heavy , delicates , whites , woollens etc
may not be exactly worded like that but you get the idea
when ever you see wash temp or water temp , select-- cold
Jul 08, 2017 | Dishwashers
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Cold water will not fill
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 27, 2011 | Maytag Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
heatman101
Mar 31, 2011 | Washing Machines
Is the indecit wm12x washng amchne a hot or cold water fill?
Hi from retired Englishman in SW France @ 13:45 Tues afternoon.
You can easily check by looking at the back where the water pipe or pipes need to be connected. If there is only one inlet then it is a cold fill and the machine will heat the water up itself.
If there are two inlets the hot is normally marked RED and the cold BLUE.
When the hot water is not hot enough for the particular wash, the machine will heat it in the same way as it would heat just cold water. If, however, the hot water is too hot, it will mix in some cold!
Cheers,
John C
Feb 08, 2011 | Miele Washing Machines
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 08, 2010 | Kenmore Washing Machines
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Washing Machines Logo
Top Washing Machines Experts
