Question about Dryers
Electric dryer frequently needs hours to dry average load
How can I check heating element? Is there more than one? Can it have some sort of ''short''? Is it possible for it to work sometimes well and other times not? It always heats, just doesn't dry well every time. I have cleaned the venting, lint trap is clean, it tumbles well.The loads are not too big. I have had it for 15 years, not a problem until now.
If you have any other suggestions, that would be great.
  • debgregandja Jan 28, 2009
    HEY SUPER MYKE!!
    YOU WERE RIGHT ON, THANKS FOR SAVING US THE BIG BUCKS ON SOMETHING MY HUBBY COULD FIX IN AN HOUR HIMSELF.... YOU ROCK!
    Problem Solver:
  • 18 Answers
Elements rarely barley work, it's either they do, or they don't. Locate the element and unplug the wires going into it. Measure the ohms, it should be between 8 & 12 (depending on the model). Your problem sounds like a thermostat, check your thermostats and heat anticipators with an ohm meter (be sure to unplug the wires going into them first). If any of them read "ol" or 'open line', that's the one that will need replaced.
Posted on Jan 21, 2009
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer takes almost 3 hours to dry a average size load, when I bought it new it took around 1 hour to do a load. Im thinking it might be a heating element but how can I be for certain that is it without...
If you have an ohmmeter you can check it , check across the element connections. Have you cleaned the vents? If the air can't get out it could cause a problem . Also is the fan working ? Lint or something may be blocking it so it can't turn or slowing it down. You might check to be sure you have 220 volts to the dryer one side might be out and only have 110 volts. If you are getting some heat the element is not completly out. One other thing check with ohm meter from heating element connections to the heater box it may be grounded which might give you 110 volts. Hope this helps.
Dec 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Leaves burn marks on clothes
Hello there:
There are normally 2 main causes for this to happen
first if it is overheating or if it is taking to long for the dryer to dry the clothes so plese check these solutions that i have provided below ok and keep me posted on this
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged clear it using your vacuum, . Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system.
May 14, 2010 | Frigidaire FDE546RE Dryer
Amana Special Edition Electric Dryer Model ALE868QAW not drying
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
Laundry not getting dry
Vent
Heating element
Internal ductwork
Cycling thermostat
Jul 18, 2009 | Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
Vent
Heating element
Internal ductwork
Cycling thermostat
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
Vent
Heating element
Internal ductwork
Cycling thermostat
May 28, 2009 | Kenmore 64902 Electric Dryer
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
Changed motor now dryer works until its too hot
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Vent
Heating element
Internal ductwork
Cycling thermostat
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Takes 2 hours to dry an average size load
in a few wods blockage,blockage,blockage.frist eazy thing is to try drying a load with out venting that will help elimanate that as a possibilty.then if still bad pop top and remove frountthe filte housing area will have a lint buildup,clean.next check the blower wheel when you turn it by hand the tub should move also.replace if free wheels.God bless you house ,tom
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
