Question about As Seen On TV Diamond Radiance
Replacement head/tips I am looking for the heads/tips that go on the top of the wand.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Www.nubrilliance.com or you can call them to order new microdermabrasion tips and filters at 1-800-423-4248. You can also find them on EBay but I would suggest bidding opposed to buying outright as they are expensive. One last thing...there also is another tip that didn't come with the original kits...that you can get...It plumps the lips!!! Hope this helps!
Posted on Jul 09, 2014
I have a kenmore model 116.25512506. The roller is spinning but no suction from the head. The attachments have suction but not the head. How do I remove bottom cover to check for blockage?
Is the suction control plastic ring shut?. If it's wide open you get almost no suction. See picture.
25823072-bhx41vpbxgcw2fhkwng0wody-1-0.jpg If that is closed check the long metal wand. Disconnect from the beater bar head and check the whole length of the wand and look into the beater bar head opening for something plugging it.
Aug 15, 2015 | Kenmore Vacuums
When the dyson is turned on the suction goes to the wand when you tip the beater down you do not have as much suction you cant pick up lint.
The Dyson system is designed to operate the hose with the handle in the upright position. When the head is tipped down (floor vacuum position) it closes the opening to the hose/wand
Nov 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
The beater does not work. the restart button is not burnt or the switch
Remove the hose and reinstall using the alignment arrow at the top of the hose insert. Be sure the hose clicks securely and does not twist or rotate right or left.
Then remove the power head from the wand and eliminate the wand. Plug the head directly onto the hose and plug the cord into the wire socket under the hose.
Flip the switch on the head fully back and forth to see if the head will run without the wand. If it runs put the wand back in place and inspect electrical connections and plug terminals when reinstalling. Post back with what you see and results
Sep 10, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Loose electrical contact in extension wand
You have a loose connection at one of several possible locations.Inspect the contacts at the top and bottom of the wand .IF they are black or coppery or look melted, both pairs of contacts, male and female will need to be replaced.
Try to wiggle and twist the wand at top, then at bottom. If this does not reveal the short, work your way back down the hose towards the a vac itself, starting behind the hose handle.
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
Brush is not turning
You may not have power to the power head. Check the plug at the neck of the power head, also the wand connections to make sure they aren't burnt. Most of these powerheads also have a circuit breaker on the top of it, press it to see if it will re-set. At the end of the hose handle, there is a female plug where the wand plugs into, push it ans see if it will move inward or not. If it does, then it has broken loose inside of the handle and isn't allowing a connection to the wand. The switch on the hose handle may be bad. The power head motor could be bad. These are the most common problems when the power head won't run.
Jan 26, 2009 | Kenmore 22812 Bagged Canister Vacuum
Replacement wand for canister
Whne you had your first problem with it, the cord at the bottom probably should have replaced also, if one end gets scrotched, the other end does also. One big reason why this happens is connecting and dis-connecting the power head while power is still applied to it. When you hook your skillet and it is turned on, it will arc, so does the contacts on the hose and power head. That prong is rusty, it is scrotched. Don't know if you can substitude, you might try to find a shop that has other wands and see if you can find a fit, either that or buy the one that is supposed to be with it.
Mar 15, 2008 | Vacuums
Power brush problem
Check the contacts where the power head attaches to the wands and also where the wnd attaches to the hose. If any of the contacts look burnt, then they will need to be replaced. Unhooking them when power is on is what causes most of these problems. But if they look ok, could be a problem inside the power head, or in the circuit board that is inside the cannister.
Feb 11, 2008 | Samsung Ultra Quiet 9073R Bagged Canister...
As Seen On TV Diamond Radiance Logo
29 people viewed this question
Top As Seen On TV Vacuums Experts
JoeVacs
Are you an As Seen On TV Vacuum Expert? Answer questions, earn points and help others
