Question about Toshiba Satellite A205-S4617 Notebook
FORET THE PASSWORD ON MY TOSHIBA SATELLITE A200-ST2
  • DEKR
    DEKR May 11, 2010
    was it the windows login password
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My toshiba satellite a200 is not respondinging to password .it wont open windows
restart the system and re-enter the password..it will work ...if this fails restart the system and press F8 while start the system and starts in Safe mode.and Login As Administrator and change the password.
Mar 30, 2010 | Toshiba Satellite Pro A200-EZ2204X...
INITIAL SETUP PASSWORD-TOSHIBA SATELLITE A200
try checking out this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1702271&rpn=PSAF0U&modelFilter=A200-ST2041&selCategory=3&selFamily=1073768663
this will resolve the issue. the good news is they are aware of it. the bad news. you gotta send in your unit to be serviced.
Good Luck!
Ruben
Jul 23, 2009 | Toshiba Satellite 2410-S203 Notebook
Toshiba a200-1VO
hi
please open the laptop then push the semos battery plz start the computer then shut down then enter the semos battery then start computer password is reset other plz install the bios this laptop
Jun 06, 2009 | Toshiba Satellite A60 Notebook
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Forgotten password to my laptop
make up a new user and then get into and reset password
Apr 30, 2009 | Toshiba Satellite Pro A200-EZ2204X...
TOSHIBA SATELLITE A200-ST2 FORGET PASSWORD ON HARD WARE
if you mean the microsoft windows login password
you need a very helpfull tools called Knoppix
it's will crack SAM on your windows system
it's can be downloaded from
http://home.eunet.no/~pnordahl/ntpasswd
it's an ISO file
download it
then burn it to a CD
then you'll need to booting with your so called knoppix CD
then:
  1. select the partition where the system located
  2. select directory where system located
  3. you can choose to reset your password so no password used in your login system
  4. write change to disk
  5. take the CD out from your optical drive
  6. and restart your computer
OR JUST SIMPLY REINSTALL YOUR SYSTEM
please rate!
Jan 21, 2009 | Toshiba Satellite A205-S4617 Notebook
Reset password on toshiba satellite pro a200
Which operating system are you using?????????
you could set a password in the BIOS, but as far as a operating system password goes, it would be difficult, at best, to reset a password without being logged in first.....
Jun 04, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite A205-S4617 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
